Elhadi
Message 111 of 116
Re: Test socket, speed shot up then down
Yes i know but i ment the actualy process of reseting the margin
Message 112 of 116
the mods will get it fixed once they contact you after you send the email so just a few days after the 3/5 working days
Elhadi
Message 113 of 116
WONDERFULL NEWS GUYS!
My noise margin was reset and now i am up in the 9mbps 😄 i am very happy and it is great that we can finally get this sorted out, thank you also everyone that helped me out!
Solved 🙂
Message 114 of 116
that's great - took a bit of time and patience but success eventuallySmiley Wink
Elhadi
Message 115 of 116
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:02:12
Downstream:9.493 Mbps
Upstream:1.062 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):6.0 dB / 6.1 dB
Line attenuation (Down/Up):35.7 dB / 19.7 dB
Output power (Down/Up):20.4 dBm / 12.7 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):8 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):24 / 0
Error Seconds (Local/Remote):16 / 18
Moderator
Moderator
Message 116 of 116
Great result Elhadi. Glad to see it's all sorted.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
