Elhadi
Message 71 of 116
Re: Test socket, speed shot up then down
Done 🙂 :
http://i.imgur.com/vJ5noj1.jpg
Removed faceplate, removed wires, pushed down 2 and 5 into new filter and put the filter back :),
Hopefully this will improve my connection and reduce the cuts already have seen an improvement straight away 😄
Thank you very much guys,
I will post in 3 days with stats
Current stats:
Line stateConnected
Connection time0 days, 0:04:16
Downstream6,115 Kbps
Upstream1,095 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)15.2 dB / 6.1 dB
Line attenuation (Down/Up)37.5 dB / 19.9 dB
Output power (Down/Up)0.0 dBm / 12.6 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 2
CRC Errors (Down/Up)0 / N/A
HEC Errors (Down/Up)N/A / 8
Error Seconds (Local)0
Message 72 of 116
yes looking better already if after 3 days stable connection your noise margin is still high then we can get the forum mods to carry out a reset for you
Message 73 of 116
assuming line now stable and when you get the 3+ days connection time then getting noise margin reset to 6db will give more conenction speed  with your attenuation I would hope for about 10mb
Elhadi
Message 74 of 116
Thank you for the replies i will wait 3+ days
weird how the mods didn't tell me to do this as i sent them the pictures too,
anyway im just happy its improving 🙂
Thanks guys.
Message 75 of 116
it is because the faceplate and extensions are your responsibility not Openreach's
Elhadi
Message 76 of 116
Well it should be their responsibility as their aim is to give the best connection to their customers thats wasnt best also the engineer fitted my router around 10 years ago lol
Anyway it doesnt matter, the important thing is it is better
Elhadi
Message 77 of 116
Crashed again Smiley Sad
I don't understand what could be causing this, i was told that it is pretty stable, 1 crash a day but you guys and me don't really think 1 crash a day is counted as "stable" anyway any suggestions.
Also the tests that were run by mods came out stable .
thanks,
Line stateConnected
Connection time0 days, 0:05:35
Downstream6,087 Kbps
Upstream1,099 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)15.0 dB / 6551.7 dB
Output power (Down/Up)0.0 dBm / 12.9 dBm
Message 78 of 116
The good thing is the speed and noise margin is still about the same so need to give time to settle after all your changes. The up noise margin looks very odd
I would repost stats again tomorrow
Elhadi
Message 79 of 116
Okay thanks, yes it looked very weird to me too xD
I will re post the stats tommorow
Message 80 of 116
As usual there is always someone around to help
