bigwave
Newbie
Message 1 of 3
Upgrade from IPStream 512Kbps to ADSL2+ request
I am on an "exchange activate"/IPStream line capped at 512Kbps.
I believe that my excahnge has been finally upgraded to WBC 21CN but I am still only get half a megabit download speed.
Is there anything a moderator can do to expedite my migration to ADSL2+?
Broadband checker and modem stats below.
Cheers,
Ian
Status: UP
Line State: showtime_tc_sync [0x801]
Line Mode: G.992.1 (ADSL)
Annex: A
Profile:
Data Rate: 576 Kb/s / 288 Kb/s
Max. Attainable Data Rate (ATTNDR): 8.128 Mb/s / 1.024 Mb/s
Latency: 0.25 ms / 0.25 ms
Line Attenuation (LATN): 8.4 dB / 8.5 dB
Signal Attenuation (SATN): 8.3 dB / 8.5 dB
Noise Margin (SNR): 43 dB / 24 dB
Aggregate Transmit Power(ACTATP): 12.1 dB / 12.1 dB
Forward Error Correction Seconds (FECS): 0 / 0
Errored seconds (ES): 1 / 1
Severely Errored Seconds (SES): 0 / 0
Loss of Signal Seconds (LOSS): 0 / 0
Unavailable Seconds (UAS): 28 / 28
Header Error Code Errors (HEC): 0 / 0
Non Pre-emtive CRC errors (CRC_P): 0 / 0
Pre-emtive CRC errors (CRCP_P): 0 / 0
Line Uptime: 34m 30s
ATU-C System Vendor ID: FF,B5,47,53,50,4E,00,07
Power Management Mode: L0 - Synchronized
2 REPLIES 2
Message 2 of 3
Re: Upgrade from IPStream 512Kbps to ADSL2+ request
I have ask mods to see if they can get you upgraded and they will post here
the info looks odd though  you are showing max speed applicable to adslmax but checker shows adsl2+ available and  with your attenuation I would expect far higher speed   see what mods can do
Moderator
Moderator
Message 3 of 3
Hi @bigwave
Welcome to the Community and thanks for your post!
I can check about the possibility of upgrading you to ADSL2.  It looks promising from what you have posted Smiley Happy
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
