motek
Message 1 of 19
Upgrade to ADSL2+
I have moved houses a couple of months ago and since then myupload speed is extremely slow. Sending an email takes ages. I did not have the same issue at my previous address. I assume I am on ADSL max, hence how coulld i upgrade to ADSL2+?
Thanks in advance
Below results of availability checker:
VDSL Range A (Clean)5539.813.38.535Available----
VDSL Range B (Impacted)44.428.211.8622.4Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 4.5--3 to 7Available----
WBC ADSL 2+ Annex MUp to 4.5Up to 0.53 to 7Available----
ADSL MaxUp to 3.5--2.5 to 6.5Available----
WBC Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date18-01-1970
18 REPLIES 18
Message 2 of 19
Re: Upgrade to ADSL2+
can you post stats from your router please
motek
Message 3 of 19
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+xxxxxxx
Firmware version:
SGxxxxxxxxxx2
Firmware updated:
11-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 2 Hours 24 Minutes 30 Seconds
Data rate:
448 Kbps / 7.17 Mbps
Maximum data rate:
1184 / 7684
Noise margin:
23 dB / 6.4 dB
Line attenuation:
43.5 dB
Signal attenuation:
26 dB / 43.5 dB
VPI / VCI:
0/38
Modulation:
G_992_1_ANNEX_A
Latency type:
Fast Path
Data sent / received:
42 MB Uploaded / 1007 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-xxxx
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-xxxx
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
xxxxxxxxxxx
Software variant:
Boot loader:
7.33.1
Message 4 of 19
you have been put on adslmax probably because your downspeed is less than 8mb  The mods will post here and try and help get you upgraded to adsl2
Moderator
Moderator
Message 5 of 19
Hi @motek,
We'll check your account and if needed, get in touch with BT Wholesale, our suppliers, to change you over. You can contact us by clicking on my user name and then on contact the mods.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
motek
Message 6 of 19
Thanks DanielS. Unfortunately I cannot find the contact the mods after clicking on your user name...
Message 7 of 19
if you are using a mobile then you need to switch to full view
motek
Message 8 of 19
Hi,
I am on my laptop.
Message 9 of 19
usually like this
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
motek
Message 10 of 19
Thats what i was looking for, however its not there
