Moderator
Moderator
Message 21 of 24
Re: Upgrade to fibre failed, reversion to Copper also failed!
Hi @BB-or-not-BB  thanks for the update. I had just completed tests and was about to post to ask you if it was working as looks fine from here.
Cheers
John
Message 22 of 24
 Thanks John. Will keep an eye on things and I’ll get back to you if we need to. I’ll send you an update again in a few days anyway just to, hopefully, confirm everything is good and stable. Really appreciate your help. Thanks. Steve
Moderator
Moderator
Message 23 of 24
Hi @BB-or-not-BB  thanks for confirming all was working ok and I take it the connection has been good over the last few days or you would have updated the thread. I'll now close the case but if you experience any issues in the future come back to the forum and we will be happy to help.
cheers
John
Message 24 of 24
Hi. Sorry I’ve been quiet. I’ve been away for a few days. The connection seems stable and has settled down at a bit over 5 which is hugely better than during our fibre connection. Thanks for your help. I think it should be safe to close this down now.
