milemil
Newbie
Message 1 of 4
Upgrading to ADSL2+
Hi, I'm not yet a BT customer, but I'm moving into a flat that's got the worst connection possible. I can't get fibre-optic because the cabinet is too full, I can only get broadband that's between 5-10mbps. Reading online I learned about ADSL2+ and how BT provides a large percentage of its customers with. I want to know if it'd be possible for me to get it. The postcode is BN1 5AD.
Thank you!
3 REPLIES 3
Message 2 of 4
Re: Upgrading to ADSL2+
Welcome to this user forum.
You will automatically be put on ADSL2+, unless you are a very long distance from the exchange.
Until you get a working BT Retail phone line, it would not be possible to determine your actual connection speed.
There are a lot of people with a much worse connection that you are quoting.
milemil
Newbie
Message 3 of 4
Alright, thank you very much!
Message 4 of 4
that postcode is the Brighton exchange which is adsl2/2+ enabled  your connection speed will depend on your distance from the exchange
