godmcgarvey
Message 41 of 81
Re: Upload faster than download! Oh dear
Well thats an engineer booked for Friday, need it sorted one way or another.
If I plug a phone in I lose connection, don't think that should happen. And as for the quiet line test, thats like rustling a crisp bag.
Get the feeling this is not going to be cheap, will probably need a new cable from pole to house as the previous is inaccessible both externally and internally.
Will BT connect straight to a first floor as opposed to ground floor?
Tags (1)
Message 42 of 81
If the line from pole need replaced then talk to the engineer about fitting to first floor and see what he says
godmcgarvey
Message 43 of 81
It would make more sense as thats where the modem and phone is.
Apart from the height you would only have one wall to go through as opposed to 2+ with the porch now in existence
Message 44 of 81
As i said you can but ask - the problem maybe somewhere else and not in the cable in the porch
godmcgarvey
Message 45 of 81
Is the engineer visit just to establish the problem?
If a cable + holes drilling is required is that another job for another day?
Hoping to get my internet and phone working by Christmas 😉
Message 46 of 81
The engineer should be there to fix your connection not just look at the problem
Message 47 of 81
please keep us posted on how things go
godmcgarvey
Message 48 of 81
Confused !
Log onto the internet today and my speed is back upto 7.9 from the previous 0.2, the engineer isn't due till Friday to check my line!
Now is this speed increase due to action from the mods?
My phone line is still nosiy so am I likely to end up back on slow speeds due to disconnects?
Should I cancel the engineer!?
I have noticed hanging up the phone disconnects the internet, is this a phone fault (brand new BT phone) or a possible line fault?
Happy with my speed increase but feel I'm still going around in circles
Latest hub stats..
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:16:57
Downstream:8.962 Mbps
Upstream:1.144 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):6.4 dB / 6.4 dB
Line attenuation (Down/Up):29.3 dB / 17.9 dB
Output power (Down/Up):20.4 dBm / 11.7 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):9 / 97
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):18 / 241
Error Seconds (Local/Remote):994 / 23
Message 49 of 81
if your line is still noisey then if that is from test socket then you still need engineer.  the line noise will probably cause your conenction to drop again with noise margin increasing and speed decreasing
godmcgarvey
Message 50 of 81
Just found a reply from the mods (thanks Patrick), unforunately my spam checker had labelled it as spam....doh
So I'm back at a faster speed, will do another check with the "quiet line". This is the first time I'm actually hoping for noise otherwise I'm going to be at a loss to know what to say to the engineer come Friday!
