bangas
Newbie
Message 1 of 3
Upload speed limited to 448 kbps.
Hi,
I'm having the same issue, with upload stuck at 444Kbps.
Did the line check and here are the results:
Can you please advise?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Upload speed limited to 448 kbps.
Hi @bangas,
Welcome to the community forum. I've moved your post to start your own thread.
I'll be able to take a look at your connection. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Moderator
Moderator
Message 3 of 3
@bangas I tried calling you there, you'll need to contact the BT business team regarding your broadband connection as we can only assist residential customers. The BT Business forum will be able to offer you advice on how you can change your connection over to ADSL2+.
