solifugo
Newbie
Message 1 of 3
Upload spped very slow
Hi,
Sorry, I know this is a common question and BT doesn't warraty a upload speed minimun, but Im starting to be very frustated about my upload spped.
Even my mobile with low signal upload speed is better han my BT line Smiley Indifferent
Anyway, I have gathered some info to try to determinate if something can be done:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number XXXXXXXXXX on Exchange LEITH is served by Cabinet 69
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
Other Offerings
Availability Date
WBC ADSL 2+Up to 7--6 to 8Available--------
ADSL MaxUp to 4--3 to 7Available--------
WBC Fixed Rate2----Available--------
ADSL Multicast------Available--------
17:58:32, 14 Dec.( 85.950000) DSL is up
17:58:31, 14 Dec.( 85.030000) DSL noise margin: 27.40 dB upstream, 6.10 dB downstream
17:58:30, 14 Dec.( 84.160000) DSL line rate: 444 Kbps upstream, 7645 Kbps downstream
As you can see above, upload speed is only 444Kbps.. And as far I have tested, I never got more than 0.5Mbs... which is really frustating.
I cheched Openreach and they have been "Building" a new Fibre cabinet for months.. for sure more than months now.. so I can not make the jump :___(
Please, could someone give me some advises?
2 REPLIES 2
Message 2 of 3
Re: Upload spped very slow
You're on regular ADSL up to 8meg at the moment which unfortunately is limited to a max of 448kbps upload.
You just need to wait for the new fibre cabinet I'm afraid!
solifugo
Newbie
Message 3 of 3
Sorry for the delay. I didnt get any notification of someone replying to this.. my bad.
I guess you are right, check on couple of friends connections and looks like is the usual speed... very frustating, but nothing can be done.
Thanks for your reply!!
