HelenG
Message 1 of 12
Very Frustrated - fluctuating and poorer connectivity
Just been on the phone to BT for half an hour trying to resolve fluctuating and poor connectivity.
Using a HH4, I used to get a fairly consistent 6.8 Mbs but now it fluctuates between 2-4Mbs. It is making life really difficult as I often work from home and I cannot get a reliable connection.
The woman at BT told me that she could see that I got approx 5Mbs but I could not. I very briefly saw 6.8 when everything was disconnected, but when I looked a second time with everything still disconnected I saw 1.3.
She told me that there was nothing further she could do as she saw me over the minimum required level of 2.5 ish and that was that.
What is going on ? Is there any chance it could be to do with my equipment or is it more likely to be something at the exchange ? Could someone PLEASE HELP !!
11 REPLIES 11
Message 2 of 12
Re: Very Frustrated
@HelenG
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Noise on the phone line will affect broadband speed.
Are you connecting to the home hub using a direct Ethernet cable, or wireless?
HelenG
Message 3 of 12
Re: Very Frustrated
Just tried that as saw the suggestion on another post. Unfortunately no, it was clear.
HelenG
Message 4 of 12
Re: Very Frustrated
Am connecting via an ethernet cable. Could it be damaged ?
Message 5 of 12
Re: Very Frustrated
Which BT Home hub do you have?
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
HelenG
Message 6 of 12
Re: Very Frustrated
BT BROADBAND AVAILABILITY CHECKER
Telephone Number on Exchange COLDINGHAM
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
ADSL MaxUp to 5--3.5 to 7.5Available----
Fixed Rate2 ----Available----
Home Hub 4
Message 7 of 12
Re: Very Frustrated
Hi Welcome to the community forums
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
This test must be done with a wired connection.
http://speedtest.btwholesale.com/
once you have posted the information asked for then the community members can help you more
Thank You
HelenG
Message 8 of 12
Re: Very Frustrated
17:06:16, 01 Dec.( 76.240000) DSL noise margin: 25.00 dB upstream, 10.10 dB downstream
17:06:15, 01 Dec.( 76.010000) DSL line rate: 448 Kbps upstream, 8128 Kbps downstream
When looking for these I found loads of entries saying BLOCKED - is that normal ?
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 3.24 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
HelenG
Message 9 of 12
Re: Very Frustrated
Do you need anything else ?
Message 10 of 12
Re: Very Frustrated
The blocked messages are just the firewall doing its job nothing to worry over
