Moderator
Moderator
Message 11 of 12
Re: Very Frustrated
Hi @HelenG and thanks for posting.
Your noise margin is a little high at 10.10dB, the target is 6dB, so if you can maintain a stable connection that should drop which in turn should increase the connection speed. Can you try connecting to the test socket behind the master socket and leave it there for a few days?
Cheers
David
HelenG
Message 12 of 12
Re: Very Frustrated
I can try -  thanks
