drkdeath5000
Message 81 of 94
Re: Very Slow Broadband Speed & Dropping Out
Just to let you know this is still a problem. I dont seem to be getting any replies and this is not resolved...
9AM and my internet is pretty much useless, i'm not even getting 1mpbs
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Windows\system32>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.18]
over a maximum of 30 hops:
  1     3 ms     4 ms     3 ms  BThomehub.home [192.168.1.254]
  2   311 ms   337 ms   382 ms  esr8.birmingham5.broadband.bt.net [217.32.86.147
  3   345 ms   377 ms     *     217.32.86.77
  4   186 ms   224 ms   200 ms  213.1.69.94
  5   173 ms   209 ms   162 ms  31.55.164.102
  6   401 ms   325 ms   337 ms  213.120.182.65
  7   223 ms   221 ms   141 ms  31.55.164.107
  8   180 ms   180 ms   182 ms  109.159.248.85
  9   196 ms   221 ms   311 ms  core1-te0-15-0-17.ilford.ukcore.bt.net [109.159.
248.174]
 10   321 ms   182 ms   134 ms  194.72.31.155
 11   398 ms   130 ms   241 ms  194.74.65.42
 12     *        *        *     Request timed out.
 13     *        *        *     Request timed out.
 14   469 ms   561 ms   580 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 15   267 ms   252 ms   271 ms  132.185.255.149
 16   239 ms   321 ms   335 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
Tags (1)
Message 82 of 94
see if mods can help again as you are not making any progress
Moderator
Moderator
Message 83 of 94
Hi drkdeath5000,
I'm sorry this is still not sorted, I've let DavidM know and he'll be in touch.
Neil
Moderator
Moderator
Message 84 of 94
I've dropped you an email today drkdeath5000.
Cheers
David
drkdeath5000
Message 85 of 94
The forum mod team have been in touch and asked me to do another quite line test which revealed the noisy line problem was back. So i am back to square one now and it seems the problem was never resolved. Broadband drops as soon as a i use the phone and the line is noisy when using adsl so exactly the same initial symptons which leads me to believe the high latency is related. Anyway a third engineer visit is scheduled for next week so i will report back once they have been.
In the meantime my connection just keeps getting worse and worse; this is the latest from the bt speedtest today 😞
Download speedachieved during the test was - 0.18 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.9 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2.5 Mbps
Message 86 of 94
You are never going to improve the connection until you get rid of the noise so hopefully engineer next week will find tbe problem
drkdeath5000
Message 87 of 94
The engineer came last week; mentioned something about me being on cross talk and went off to change wiring from the post to the exchange? I dont have the slightest clue what he's done but its been much better this time, i'm averaging on 6 - 7.5mbps and pings are averaging at 40-120ms. Now that ping is still a little high for my liking, my previous adsl line very rarely went over 60ms but this one does it quite frequently. Still its useable i just wish it could be better. I'm not much of a gamer these days but played a few different online games last night and noticed my ping spiking from 60ms to 120ms every 2 minutes or so making it quite difficult to play. Maybe the connection is yet to stabilise but its been 5 days now so i'm not so sure. I'm seeing similar spikes when running MTR or traceroutes to bbc.co.uk and google.co.uk.
  1    <1 ms    <1 ms    <1 ms  BTHUB4 [192.168.1.254]
  2    80 ms    37 ms    60 ms  esr8.birmingham5.broadband.bt.net [217.32.86.147
  3    89 ms    38 ms    37 ms  217.32.86.77
  4    38 ms    39 ms    38 ms  213.1.69.14
  5    38 ms    38 ms    37 ms  31.55.164.102
  6   178 ms   119 ms    64 ms  31.55.164.49
  7    39 ms    79 ms    38 ms  31.55.164.107
  8    38 ms    38 ms    38 ms  109.159.248.83
  9    52 ms    46 ms    47 ms  core1-te0-3-0-15.ealing.ukcore.bt.net [109.159.2
48.28]
 10    44 ms    43 ms    42 ms  peer2-xe3-1-1.telehouse.ukcore.bt.net [109.159.2
54.233]
 11    43 ms    44 ms   101 ms  194.74.65.42
 14    45 ms   156 ms    65 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 15    80 ms    45 ms    45 ms  132.185.255.149
 16    68 ms    43 ms    45 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
  2    38 ms    38 ms    37 ms  esr8.birmingham5.broadband.bt.net [217.32.86.147
  3    55 ms   152 ms   150 ms  217.32.86.77
  4    39 ms    39 ms   179 ms  213.1.69.14
  5   137 ms    65 ms    38 ms  31.55.164.102
  6    38 ms   126 ms   149 ms  31.55.164.49
  7    38 ms    38 ms    38 ms  31.55.164.107
  8    37 ms    38 ms   116 ms  109.159.248.83
  9    44 ms   106 ms    47 ms  core2-te0-15-0-17.ilford.ukcore.bt.net [109.159.
248.42]
 10    43 ms    94 ms    42 ms  peer2-xe3-1-1.telehouse.ukcore.bt.net [109.159.2
54.233]
 11    41 ms    42 ms    43 ms  194.74.65.42
 14    45 ms    47 ms    44 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 15    64 ms    46 ms    46 ms  132.185.255.149
 16   116 ms    43 ms    80 ms  fmt-vip72.telhc.bbc.co.uk [212.58.244.18]
Trace complete.
Message 88 of 94
could you please post your current adsl stats and the further diagnostics section of the BT speedtest
drkdeath5000
Message 89 of 94
ADSL stats from router logs-
13:43:11, 05 Aug.( 74.520000) DSL noise margin: 30.00 dB upstream, 14.10 dB downstream
13:43:11, 05 Aug.( 74.450000) DSL line rate: 448 Kbps upstream, 8128 Kbps downstream
Download speedachieved during the test was - 6.87 Mbps
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
Message 90 of 94
stats look good with max conenction speed and correct profile
