jaysteadman
Message 11 of 15
Re: Very Slow Speed .
Thanks for the advice , I shall do the quite line test tomorrow .
Cheers Smiley Happy
jaysteadman
Message 12 of 15
I rang the bt help line again as our speed is still very slow . I was told it would now be another 14 days for the line to regain its speed .
Which would be in total six weeks of quite poor speed and quite below the minimun speed for our package .
Message 13 of 15
did you try quiet line test?
can you post router stats please
jaysteadman
Message 14 of 15
Yes I did the quite line test and the line was noisey , when I called the bt helpline the other day , they said the line was okay from thier end .
I have brought some new mirco filters to see if that will help.
Message 15 of 15
are you using the test socket now with the new filter?  if so is there still noise on quiet line test?  if so then you need to report phone fault not broadband to 151
