Renegade_Pirate
Message 1 of 23
Very slow broadband speed !
For the past few weeks we've had broadband speeds so slow that it's pratically unusable at times.
A few days after the problem began I renewed/changed my broadband package from 10Gb to unlimited, but this is infact pointless (other than unlimted costs me less per month than a capped rate !) as we couldn't get decent enough speed to downalod 10Gb in a month never mind any other higher cap.
I've ran all the speed/line tests and so on, and at best get 0.67 from the exchange to the hub ! On a few occasions I get 0.38 !!! Even the online broadband checker says that's poor, but the suggestions are all a waste of time (eg try a different filter, use the 'test' port behind the faceplate etc) and nothing has improved the speed.
Speaking to a chap on the phone his suggestions were 'get infinity' (no chance of that in my area for a few years apparently) or wait until BT has finished buying EE and has improved 4G then use 4G instead. I kid you not, that was a genuine suggestion !
The only other solution was wait a few days to see if it settles down. SETTLES DOWN ????? That's a joke. It's been unusable for weeks and I should do nothing but wait 3 days for it to settle down ? As a matter of fact, that's why I'm writing this, as many days later, it still hasn't "settled down".
If I honestly thought I would get faster speeds from another company I would ditch BT in a heartbeat and go elsewhere, but despite not living in the middle of nowhere, no other company can offer anything better.
22 REPLIES 22
Guru
Guru
Message 2 of 23
Re: Very slow broadband speed !
Hi
Sorry to hear that your having issues with your BT Retail services.
You will either be on the ADSLMax (upto 8mbps) service or if your exchange has been BTw 21cn upgraded you maybe on the ADSL2/2+ (upto 12/20mbps) service depending on your line quality and length.
However these upto speeds may not be the speeds you will get as ADSL broadband connections are very dependent on the distance from your property to the exchange and the quality of your line. The further away you are from your local exchange the slower your broadband speed will be.
To enable the community to help you please see the advice below: Please see Keith's help guide here: Helping forum members to help you, it will guide you through sone steps.
Please can you do the following:
2) Can you please run a BT speed test (including IP Profile) http://speedtest.btwholesale.com (not beta version)[Best done with a wired, Ethernet, connection] After Quick Test is done you need to click "Further Diagnostics" to get IP Profile.
3) is there any noise on your line. dial 17070 option2 ,called quite line test, from landline phone. should be silent but slight hum normal on cordless phone.
4) please post adsl line statistics
5) Please can you copy and paste the information for you line from http://dslchecker.bt.com/adsl (make sure you edit out your landline number before posting though)
ADSL Line Statistic Help:
If you have a BT Home Hub like the one below...
Then:
1) Go to http://192.168.1.254 or http://bthomehub.home
2) click Settings
3) Click Advanced Settings
4) Click Broadband
5) Click Connection or sometimes called ADSL (see picture Below)
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3.A firmware ending in 1.3)
or http://bthomehub.home/index.cgi?active_page=9118 (for bthomehub3.A firmware ending in 94.1.11)
You will need to copy and past all the adsl line statistics ( Including HEC, CRC and FEC errors). You may need to click " More Details"
If you have a HomeHub 4 then the majority of the ADSL Stats shown in the previous Hubs will not be there.
for HH4 users you can go to hub manager then select troubleshooting then logs and are look for 2 entries together which will show theconnection speed and noise margin for when your HH4 last sycned with the exchange.
There are more useful links on Keith's website here: If you have an ADSL connection, please select this link
Don't have a BT Homehub/Voyager?
http://192.168.0.1 for a netgear router and look for ADSL adsl statistics with information like noise margin and line attenuation, connection speed
http://192.168.2.1 for a belkin router and look for ADSL adsl statistics with information like noise margin and line attenuation, Data Rate
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Renegade_Pirate
Message 3 of 23
thanks. I've done all the tests before, but will do them again and post the results. may be a day or two before I can do so. thanks.
Message 4 of 23
just post when you can as forum members cannot help without some basic information
Renegade_Pirate
Message 5 of 23
I have to borrow a laptop with ethernet (all my home devices are wireless) to do the testing, then bring the results back into work to post, as the home speeds are too slow ! I'll get it done ASAP. Cheers!
Renegade_Pirate
Message 6 of 23
Best Effort Test:
Download speed achieved during the test was - 0.6Mbps
For your connection the acceptable range of speeds is 0.4Mbps - 1Mbps
IP Profile for your line is - 0.62Mbps
Upstream TEst:
Upload speed achieved during the test was 0.38Mbps
Additional Information:
Upstream Rate IP profile on your line in 0.45Mbps
Renegade_Pirate
Message 7 of 23
NO noise on line
Renegade_Pirate
Message 8 of 23
ADSL Line Status - before power cycling the Home Hub
Connection information
Line state: Connected
Connection time:  6 days, 23:06:41
Downstream: 705Kbps
Upstream: 448Kbps
  ADSL settings
Connection
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Fast
Noise margin (Down/Up):  7.0 dB / 15.0 dB
Line attenuation (Down/Up): 57.0 dB / 31.5 dB
Output power (Down/Up): 12.9 dBm / 12.8 dBm
FEC Events (Down/Up):  0 / 6
CRC Events (Down/Up): 81271 / 154
Loss of Framing (Local/Remote):  0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
HEC Errors (Down/Up): 12406 / 72
Error Seconds (Local/Remote):  0 / 0
Renegade_Pirate
Message 9 of 23
ADSL Line Status - after power cycling the Home HUb
Connection time: 0 day, 00:01:55
Downstream: 704 Kbps
Upstream: 448 Kbps
  ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up):  6.5 dB / 15.0 dB
Line attenuation (Down/Up):  57.5 dB / 31.5 dB
Output power (Down/Up): 12.5 dBm / 12.8 dBm
FEC Events (Down/Up):   0 / 0
CRC Events (Down/Up):  0 / 0
HEC Errors (Down/Up):  0 / 0
Renegade_Pirate
Message 10 of 23
BT BROADBAND AVAILABILITY CHECKER
Telephone Number XXXXXXXXXXX on Exchange DALKEITH is served by Cabinet 49
  • WBC ADSL 2+     :  Downstream Line Rate (Mbps) Up to 2      Downstream Range (Mbps) 1 to 3
  • ADSL Max           :  Downstream Line Rate (Mbps) Up to 2      Downstream Range (Mbps) 1 to 3
  • WBC Fixed Rate   :  Downstream Line Rate (Mbps)   2
  • Fixed Rate           :  Downstream Line Rate (Mbps)   2
  • Other Offerings    :    --
  • Copper Multicast   :   --
