peter12
Newbie
Message 1 of 5
Very slow internet
My connection has always been incredibly slow, but recently it has become almost unusable:
Connection information
Line state:Connected
Connection time:6 days, 00:28:01
Downstream:714 Kbps
Upstream:321 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):53.9 dB / 25.5 dB
Line attenuation (Down/Up):22.0 dB / 11.2 dB
Output power (Down/Up):0.0 dBm / 10.1 dBm
FEC Events (Down/Up):2 / 379
CRC Events (Down/Up):0 / 85
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):0 / 138
Error Seconds (Local/Remote):0 / 34
What can I do?
4 REPLIES 4
Message 2 of 5
Re: Very slow internet
Your noise margin is very high as normal is about 6db
can you connect to test socket with a new filter and post your stats again test socket.jpg
peter12
Newbie
Message 3 of 5
Done. Here are the results when connected to the test socket:
Line state:
Connected
Connection time:
0 day, 00:01:23
Downstream:
13,776 Kbps
Upstream:
1,214 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Interleaved
15.1 dB / 6.1 dB
19.5 dB / 9.5 dB
0.0 dBm / 12.6 dBm
0 / 0
0 / 0
0 / 0
0 / 0
0 / 0
0
0 / 0
0 / 0
I assume this means the problem is on my side.
After reconnecting to the original socket the B symbol on my hub started flashing orange and has been doing so for a few seconds every couple of minutes. Here are my stats now:
Line state:
Connected
Connection time:
0 day, 00:00:31
Downstream:
11,389 Kbps
Upstream:
1,200 Kbps
  ADSL settings
VPI/VCI:
0/38
Type:
PPPoA
Modulation:
G.992.5 Annex A
Latency type:
Interleaved
13.1 dB / 3.6 dB
19.0 dB / 9.6 dB
0.0 dBm / 12.8 dBm
0 / 26
0 / 2
0 / 0
0 / 0
0 / 0
0
0 / 1
0 / 0
Thanks for the help!
Message 4 of 5
Looks like you have an internal wiring problem which you need to solve.  Have you removed the bellwire from terminal 3 in all your sockets.
bellwire removal
Message 5 of 5
once your noise margin resets to the 6dB level you should see a further increase in speed
