winelight
Message 1 of 5
Where should my extensions be wired to the master socket?
I have a newly installed BT master socket with a clip-on Mk4 faceplate. The telephone extensions are wired directly to two screw terminals on the master socket backplate, not plugged into the faceplate. Is this correct? How are they filtered? Isn't the filter in the faceplate? I thought the whole point is that they would be filtered by the faceplate filter. What am I not understanding here?
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Where should my extensions be wired to the master socket?
They should be connected as shown here, nowhere else, as they are the filtered terminals.
Extension wiring pointExtension wiring point
winelight
Message 3 of 5
This is what I've got. Which I think is the save as what you're showing.
imjolly
Message 4 of 5
that's where your extensions should be wired
Keith_Beddoe
Message 5 of 5
Later ones were white.
That should only be your extension wiring. You can prove this by leaving the front plate off, then plugging a phone into the test socket at the top.
You should get dial tone at that test socket. If you do not, then the socket is incorrectly wired.
As @imjolly  has said, the only wires connected to that white block, should be the ones going to your phone extension. There must be no incoming wires from the external network connected to that block.
