TwoPhotons
Message 1 of 14
Why is my broadband connection so slow?!
Using a BTHub4 with an ADSL2+ connection. My PC is connected via ethernet.
Latest speedtest (BT):
Download: 3.45Mbps
Upload: 0:00Mbps
Ping: 215.83
We usually receive ~13Mbps for download, ~900kbps for upload and ~30ms for ping.
There is no noise on the phone line.
The ADSL cable goes into the master socket.
I have been having issues for a long time now. Here's my story:
I owned one BTHub4 router up until a week ago. Since December it was broken however, because the speeds I got from it were very slow (about the same as the ones right now, with a characteristic '0.00' for upload speed!), so I was instead using my 'backup' router, a DSL-2780 from TalkTalk, which worked perfectly. About two weeks ago I happened to complain to BT after waiting many months and received a replacement BTHub4 router, which I left alone because I didn't really need it if the DSL was working fine.
On Monday, I suddenly experienced frequent internet connection drops on the D-Link (around the afternoon), and later that day the internet stopped working on my D-Link AT ALL. I could not get onto any website, because if I tried to, a message popped up from BT saying something like "You must close browser and internet connection before attempting to reconnect, there are 5 possible reasons for this...", very strange behaviour. So I switched to my replacement BTHub4 router and alas, while I can access webpages, the internet is painfully slow.
Is this some sort of throtting I'm experiencing? Why am I suddenly unable to access the internet at all through the other DSL-2780 router?
I will try to get a copy of that BT message I'm seeing on my D-Link.
Please help! Thanks in advance.
13 REPLIES 13
Message 2 of 14
Re: Why is my broadband connection so slow?!
if you have hh4 conencted can you go to troubleshooting then logs and you are looking for 2 line together showing conenction speed and noise margin
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
TwoPhotons
Message 3 of 14
Thanks for the quick reply.
Here are the stats:
21:51:15, 16 Jun.   ( 106.400000) DSL noise margin: 6.00 dB upstream, 9.10 dB downstream
21:51:14, 16 Jun.   ( 105.380000) DSL line rate: 66 Kbps upstream, 13428 Kbps downstream
Message 4 of 14
your down speed is 13mb but you up is almost non existent.  can you use the test socket instead of the master especially if you have extension sockets - or do you have an SSFP
TwoPhotons
Message 5 of 14
I have to apologize, the router isn't connected to the master socket. It's connected to a standard socket. Failed to recognize it, sorry!
Message 6 of 14
so is it possible to conenct to test socket with new filter to see if that improves your conenction
TwoPhotons
Message 7 of 14
OK, I think my router is connected to the master socket but it's not the usual version (it looks like a 'standard socket', our phone line is very old), so I don't think we have a test socket. I'm not very knowledgeable about this though.
I changed to another filter, but nothing's changed.
EDIT: The socket looks like this:
Message 8 of 14
If you changed filter then hub has reset so can you post new stats please
Just a standard socket. That is where the openreach line comes in from outside
TwoPhotons
Message 9 of 14
Yep:
17:34:29, 17 Jun. (67480.710000) DSL noise margin: 6.00 dB upstream, 9.00 dB downstream
17:34:26, 17 Jun. (67478.460000) DSL line rate: 72 Kbps upstream, 13428 Kbps downstream
Message 10 of 14
That's not any better
Can I suggest as a last resort you try a factory reset using the recessed button on the back and hold till lights flash and see if that helps
