Message 11 of 11
Re: Will the newest BT Smart Hub improve existing **bleep** broadband speed?
Your cabinet already is fibre enabled (has been since 11th June 2016) however you must be too far from that too, to be able to benefit 😞
I would suggest contacting connecting devon and somerset and see what, if any plans they have for your postcode.
