Rachie80
Newbie
Message 1 of 9
Wireless light flashing when laptop is off
Is my router being used by someone else in the street when I see the wireless light flashing randomly after I have turned my laptop off?
Distinguished Guru
Message 2 of 9
Re: Wireless light flashing when laptop is off
Hi Rachie80 and welcome
Does it flash when your laptop is connected?
If the router in use is a BT Home Hub and the wireless light is flashing:
Version 1.0 - Wireless in use
Version 1.5 - Registering Wireless
Version 2.0 - Wireless registration mode
I'd have to say that if it's a V1.5 or V2.0 then the hub could be failing...
...I could be wrong though
-+-No longer a forum member-+-
Rachie80
Newbie
Message 3 of 9
Hi
Thanks for replying.  My laptop was shut down last night when I noticed the wireless light flashing so automaticcaly I am thinking someone else was connected however I am security enabled so cant figure it out.
Its a new hub as I have just switched from residential to a business tariff if that is any help.
Cheers
rachel
Message 4 of 9
Its quite normal for the wireless light to flash. There is always background Ethernet and wireless activity.
Also business hubs and all new home hubs have BTOpenzone and FON enabled by default, so it could easily be someone using your hub as a hotspot.
You should be able to look at the network devices menu on your hub, and see who is connected. Not sure where that is on the new home hub, as I have an old version.
Forumhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
Geoff93
Recognised Expert
Message 5 of 9
On a HH2a you can see the number of FON devices by clicking on Services then BT FON. Don't know if you can see the actual device because I have never seen one. Not found anywhere that shows Open zone devices but not sure if anybody has tried.
Distinguished Guru
Message 6 of 9
Mmm. None of my BTHHv2.0s have a flashing wireless light
(except on a reboot - which is normal)
I still think it's got a problem...
Distinguished Guru
Message 7 of 9
I don't know about the Hub 2.0s, but the 1.5 hub has the option of setting the wireless light to always on or flashing when there's traffic.
Geoff93
Recognised Expert
Message 8 of 9
the 2.0a has the option to make the lights flash if you want - don't by default. using a to z select lights.
Distinguished Guru
Message 9 of 9
On the HH2, you can set the BB, Wireless and Phone lights to flash.
You can't set just the wireless.
edit. Ayup, Geoff wasn't there a moment ago!Smiley Very Happy
