Message 1 of 14
Zero upload speed AGAIN!!!!!!
After several weeks of being able to work from home & use Skype or Zoom for meetings BT have turned down the Broadband so we are back to square one:
Download 1.57, Upload a big fat ZERO
If this is not resolved I will cancel payments and move to the alternative being used by a neighbour in our village.
Thank you BT for making lockdown even more miserable!!!
13 REPLIES 13
Anonymous
Not applicable
Message 2 of 14
Re: Zero upload speed AGAIN!!!!!!
Hello @mrunhappy1,
I do understand where your coming from, right do you still have a active connection right now or not?
Kind regards,
DanTMan64
Message 3 of 14
Phone line is working fine
Message 4 of 14
Did mods manage to get you upgraded to adsl2?
can you post stats from router
can you run btspeedtester and post results
if you move to another ISP your connection will still be same copper wire just pay someone different
Message 5 of 14
OK
How do I get stats from router pls?
Down = 1.57. Up = 0.
Anonymous
Not applicable
Message 6 of 14
Hello again @mrunhappy1,
By typing into your web browser 192.168.1.254. Click 'Advanced Settings' then click on 'Technical Log' copy & paste it here.
Kind regards,
DanTMan64
Message 7 of 14
That didnt get me into Tech Log
Anonymous
Not applicable
Message 8 of 14
How you mean it didn't get you into the Tech Log?
Kind regards,
DanTMan64
Message 9 of 14
Did as instructed
Went to Adv Settings
No option "Tech Log"
Message 10 of 14
Tried 3 more times, no Tech Log option
