Kerridge
Message 1 of 29
banded profile slow speed
hi could some one take a look at my profile. 2 weeks ago we had a lot of rain and there was crackling on my line till it dryed out. that is when my speed droped from 3 meg down to half a meg
28 REPLIES 28
Kerridge
Message 2 of 29
Re: banded profile slow speed
Kerridge
Message 3 of 29
Message 4 of 29
As You have 4 days stable connection see if mods will get you out of banding. They will post here
before I ask mods can you try 1 reset and see if that gets speed back. Post stats after reset and if no change then I will ask mods
Kerridge
Message 5 of 29
Message 6 of 29
Still stuck so see if mods can help
Kerridge
Message 7 of 29
thanks for your help
Moderator
Moderator
Message 8 of 29
Hi @Kerridge
Welcome to the community and thanks for your post!
Sorry for the problems you're having with your broadband speed.  You can send us over your details and we will help you with this from here.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Kerridge
Message 9 of 29
thank you my broadband is back to 3.3 meg. but i have noticed that bt wifi has switched its self back on and i have it turned off in my profile
thank you tom kerridge
Kerridge
Message 10 of 29
hi i think the invertor from my solar panels has been makeing my broadband router disconect.have now moved the router and the line is now stabe but the speed had droped from 3.3meg to half a meg
