Kerridge
Message 11 of 29
Re: banded profile slow speed
Message 12 of 29
You need to maintain a stable connection and DOM should start to reduce noise margin and increase speed probably after 3/5 days
Kerridge
Message 13 of 29
hi it has been stable for five days two hours
Message 14 of 29
I would wait another couple of days then post the stats from your hub again showing stable connection.  then try 1 reset and see if that gets speed back but if not repost stats and see if mods will help again
Kerridge
Message 15 of 29
have been onto bt and they are sending a broadband  engineer out on the 17-05-18
Tags (1)
Kerridge
Message 16 of 29
have had a txt and a mseeage from bt to say my is now fine and they found a fault at the exchange.
got back on to bt as my broadband speed is still only 572kbps and they say there is no fault with my line
and the minimum for my line is 512kbps so i am getting 60kbps over my minimum contacted speed (splitting hairs)
all i want is the dynamic line management
I feel like telling them where to stick it but im to polite
Kerridge
Message 17 of 29
sorry dynamic line management reset so i can get back to 3 meg
Message 18 of 29
If you tried1 reset can you post current stats please
Kerridge
Message 19 of 29
Message 20 of 29
If you have already found the cause of the router dropping connection I cannot see what an engineer is going to do apart from not find a problem. No point in asking mods to get you out of banding until engineer has been
