Kerridge
Message 21 of 29
Re: banded profile slow speed
bt has cancelled the  engineer after the fault was found at the exchange.but i was told by bt when i phoned that all they did was check the line and said it was stable
Kerridge
Message 22 of 29
so after a power cut last night and the hub was restarted again i am down to 283kbps download speed. have been back onto bt and told then this is below my minimum speed 512kbps and engineer no2 is now book for tuesday.
all i want is the dlm reset
Message 23 of 29
as long as line is now stable then it may release banding before tuesday  otherwise it will be same as last time and banding was put on again as line kept dropping connection
if no joy after engineer on tuesday then post back
Kerridge
Message 24 of 29
it has only been droping when bt has been testing my line and the power cut last night
Message 25 of 29
then it may release the banding by tuesday as normally on take 3/5 days stable and mods released it before when stuck
Kerridge
Message 26 of 29
thank you for your help
Kerridge
Message 27 of 29
hi all bt have reset line today and im back up to 3.3meg
Message 28 of 29
It is probably that your line has reset on its own just like it should. As long it is now stable you should be able to keep your current speed
Kerridge
Message 29 of 29
no they rang me to say the had reset it
