fishgutt
Message 1 of 29
broadband keeps on going off twice an hour.
hello, i seem to be having the same problem as a few on here.
for the last few weeks or so,my broadband keeps cutting itself off and coming back on.
this happens twice or more in a hour,it could lose connection for anywhere upto 5-10 seconds or 5-10 minutes but always seems to come back.
its also a lot worse in the day time. this is obviously no good for online gaming.
i have it connected to the test socket i have changed wires and filters and all that.
here is my adsl page. it says ive been connected for nearly 50 mins.it has reset itself because i didnt touch it.
any help would be appreciated.thanks
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 00:48:15
Downstream6,272 Kbps
Upstream840 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)6.4 dB / 10.8 dB
Line attenuation (Down/Up)46.1 dB / 22.5 dB
Output power (Down/Up)9.6 dBm / 1.2 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)1730 / 2
CRC Errors (Down/Up)14 / 2
HEC Errors (Down/Up)250 / 0
Error Seconds (Local/Remote)
11 / 2
28 REPLIES 28
Message 2 of 29
Re: broadband keeps on going off twice an hour.
have you tried the quiet line test dial 17070 option 2 you should here no noise
fishgutt
Message 3 of 29
yes mate  have tried the quiet test and everything seems quiet.
its also still reseting itself.
ADSL line status
Line stateConnected
Connection time0 days, 06:54:43
Downstream5,773 Kbps
Upstream808 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)9.2 dB / 10.5 dB
Line attenuation (Down/Up)46.2 dB / 22.5 dB
Output power (Down/Up)10.2 dBm / 1.2 dBm
FEC Errors (Down/Up)486 / 0
CRC Errors (Down/Up)57 / 0
HEC Errors (Down/Up)1474 / 0
Error Seconds (Local/Remote)7 / 0
Message 4 of 29
speed has dropped and noise margin increased which should help stabilise the line hence the 5hrs connected. do you use an extension cable when you are connected to the test socket?  there are no christmas lights near the connection?
check here for good housekeeping of cables etc
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
fishgutt
Message 5 of 29
well i used the home hub handset for the test anyway.
i just used the phone to phone the council and the line was terrible with cracks and pops,and was really quiet.
so was that my line or theirs?
getting pretty annoying now.
cheers.
edit; i use the wire that came with the home hub no extension wires. and no definatly no christmas tree wires.
unless my neighbour underneath my flat has an xmas tree in his bedroom,which i seriously doubt 🙂
Message 6 of 29
can you use normal phone not hub phone and try quiet line test  dial 17070 option 2  should hear nothig using corded phone or maybe dull hum if cordless
drake178
Message 7 of 29
If the cracks are on your line you'll also hear them during the quiet line test. Does the broadband light on your hub stay blue or does it go to flashing orange or red?
fishgutt
Message 8 of 29
i thought the home hub phone was considered cordless?
anyway not possible at the minute,the people i know near me dont own phones or have the home hub.
and as was trying to post this,it has reset itself again.took about a minute.
ADSL line status
Line stateConnected
Connection time0 days, 00:01:53
Downstream6,559 Kbps
Upstream752 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)6.0 dB / 7.2 dB
Output power (Down/Up)10.0 dBm / 1.1 dBm
FEC Errors (Down/Up)10 / 101
CRC Errors (Down/Up)483 / 855
HEC Errors (Down/Up)7917 / 0
Error Seconds (Local/Remote)9 / 81
fishgutt
Message 9 of 29
no noise on the quiet line at all.
also the broadband flashes red/orange along with the phone light.
Message 10 of 29
is the connection dropping everytime the phone is used whether incoming or outgoing calls?
