fishgutt
Message 11 of 29
Re: broadband keeps on going off twice an hour.
no mate i hardly use the house phone and the majority of the time it lies there with the battery dead or sat in its cradle on the router. i maybe get three missed calls a month.
and today was the first time i have used it in months.
drake178
Message 12 of 29
I think what he meant to ask was whether you got disconnected when you called the quiet line test or the council line.
I can only think of 2 things that can cause this (I'm sure others will come up with more):
1) Faulty router (this would be my guess)
2) Something wrong at the exchange (ie you get disconnected form the other side)
The first one you could test for if you could borrow a router form someone. Both problems likely require some form of BT assistance to solve though.
fishgutt
Message 13 of 29
no disconnection when trying the line test.
its just reset itself 3 times in as many minutes.
i could possibly get a spare router to try.just seems a bit weird that its happening in the daytime rather than the evenings.
Message 14 of 29
Did you look at the link imjolly posted about housekeeping
Message 15 of 29
Which home hub do you have?
fishgutt
Message 16 of 29
yes, i read that.
nothing has changed and its been in the same place since i got it.
drake178
Message 17 of 29
I guessed HH2 from the hub phone.
Message 18 of 29
There are known problems with the HH2.
Reported problems with the Home Hub 2.0
The clue is usually in the event log.
fishgutt
Message 19 of 29
how do i see the event log on the HH2?
drake178
Message 20 of 29
On the HH3 it's on the Troubleshooting page of the config site, I'd assume it's somewhere there on the HH2 too, I'll check too in case you don't find it.
Edit: Yes it's there on the HH2 too.
