fishgutt
Message 21 of 29
Re: broadband keeps on going off twice an hour.
thanks..
Recorded events
Time and dateMessage
Dec 31 13:18:13 2012(63897.800000) Admin login successful by 192.168.1.77 on HTTP
Dec 31 12:45:09 2012(61913.830000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Dec 31 12:44:51 2012(61895.480000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:44:51 2012(61895.480000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:44:51 2012(61895.480000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:44:51 2012(61895.480000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:44:51 2012(61895.430000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:44:51 2012(61895.430000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:44:51 2012(61895.430000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:44:51 2012(61895.430000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:44:43 2012(61887.230000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:44:43 2012(61887.230000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:44:43 2012(61887.230000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:44:43 2012(61887.230000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:44:21 2012(61865.730000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:44:21 2012(61865.730000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:44:21 2012(61865.730000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:44:21 2012(61865.730000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:44:21 2012ERR 2012-12-31T12:44:21Z cwmp: mt_cwmp: session error: Could not resolve host
Dec 31 12:44:20 2012(61864.830000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:44:20 2012(61864.830000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:44:20 2012(61864.830000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:44:20 2012(61864.830000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:44:20 2012(61864.770000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:44:20 2012(61864.770000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:44:20 2012(61864.770000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:44:20 2012(61864.770000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:27:52 2012(60876.760000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Dec 31 12:27:05 2012(60829.520000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:27:05 2012(60829.520000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Dec 31 12:27:05 2012(60829.520000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Dec 31 12:27:05 2012(60829.520000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Dec 31 12:25:38 2012(60742.880000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Dec 31 12:25:23 2012(60727.850000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Dec 31 12:25:23 2012(60727.850000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
fishgutt
Message 22 of 29
thats the last hour it wouldnt let me post it all.
Message 23 of 29
Please could you reset the home hub to factory default, as its possibly a corrupted config file.
There is a recesses reset button on the side.
fishgutt
Message 24 of 29
ah , i did this when black ops 2 came out as i thought it was me and not the game being rubbish. i also restored my config file back to it,so it probably is something to do with that.
now the only problem is finding a pin again to do it 🙂
will try now.
cheers.
fishgutt
Message 25 of 29
well its been on an hour now.
i noticed the saved restore file was modified on the 8th of this month,which is about right since ive been having this problem.
the events log now has a couple of errors but that was when it was resetting,and 3 admin login sucessfully entries.
so i will let you know how it is tomorrow before we see if is solved.
here is the adsl
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 01:13:29
Downstream6,104 Kbps
Upstream888 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)5.6 dB / 8.2 dB
Line attenuation (Down/Up)46.1 dB / 22.3 dB
Output power (Down/Up)9.2 dBm / 1.3 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)1182 / 12
CRC Errors (Down/Up)4 / 0
HEC Errors (Down/Up)50 / 0
Error Seconds (Local/Remote)3 / 0
Message 26 of 29
It quite possible that your saved file was corrupted, and when it was reloaded, the home hub tried to run the scripts, and it resulted in some basic settings being overwritten.
Its quite easy for an "illegal" charactor string to be inserted into the config file, and this can cause the script to do strange things.
It a thing that I have to watch on my home hub 1, if I manually edit the config file Smiley Wink
The firewall settings are easily upset.
fishgutt
Message 27 of 29
well it all seems to be working now.
thankyou very much for all your time and trouble. much appreciated.
ADSL line status
Line stateConnected
Connection time1 days, 19:03:27
Upstream888 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)6.7 dB / 8.0 dB
Output power (Down/Up)9.6 dBm / 1.3 dBm
FEC Errors (Down/Up)8324 / 0
CRC Errors (Down/Up)328 / 0
HEC Errors (Down/Up)5026 / 0
Error Seconds (Local/Remote)91 / 0
Message 28 of 29
Excellent Smiley Happy
fishgutt
Message 29 of 29
excellent indeed. cheers once again.
