Don01
Message 1 of 30
broadband speed problems
Hello Everyone
My first post here I sorry that its asking for help but I have seen others getting help from here and that mods can look over your case, I Thank you in advance for your help and hope you can help me too 🙂
A couple of months back I was quite happy with my internet getting 2mb and then one day it crashed and was only getting 0.1mb after 2 weeks of phoning and an engineer coming out which he replaced the wall socket, ads filter and new hun3 he even went and checked the local exchange box at the end of the street which he thought in there was a card? That needed replacing but they where expensive! He got my internet back up and running and I've now only been getting the 1mb which was dropping to 0.5mb at times then it went off again which after I called was up and running within 24hrs I also said I wasn't happy with my slow speed so they are trying to fix but this keeps going up and down. I live 3 miles from the main exchange and when I put my number into the bt web site it say my line is capable of speed between 1 to 3.5mb and I should be getting 2mb even when I renewed my contract they said I would get 2mb. So the problem is that the speed is up and down when they call me every morning its a different speed the best I have got has been 2.2 and later that day drops to 0.9 and then it wont go past 1.2 yesterday when they called it was 1.8but he said I should be getting over the 2 so keep case open and try again this morning when they called its back to 1.2mb
I was hoping that you could have a look over my hub stats below which are the last 3 I copied and there is any help you can provided me with in getting this resolved, I was hoping to get bt-vision but this in a minimum of 2mb and I can even watch a youtube without buffering, I also look forward to the day I can get bt-fiber. Many Thanks Please help and I'll stay positive 🙂
26/04/12 @5.15am
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 02:41:33
Downstream: 2.491 Mbps
Upstream: 577.7 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.3 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 3.2 dB / 8.9 dB
Line attenuation (Down/Up): 63.7 dB / 42.0 dB
Output power (Down/Up): 17.3 dBm / 12.6 dBm
FEC Events (Down/Up): 23547 / 13
CRC Events (Down/Up): 34 / 1
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 178 / 3
Error Seconds (Local/Remote): 16841 / 2100
Updated setting after bt reset line (24/04/12) 11.15am
ADSL Line Status
Connection time: 0 days, 03:09:14
Upstream: 630.2 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 3.1 dB / 5.2 dB
Line attenuation (Down/Up): 63.7 dB / 42.1 dB
Output power (Down/Up): 17.2 dBm / 12.6 dBm
FEC Events (Down/Up): 31351 / 951
CRC Events (Down/Up): 24 / 57
HEC Events (Down/Up): 331 / 21
Error Seconds (Local/Remote): 34 / 908
Connection Information. (Test 1 original settings)
Connection time: 0 days, 00:19:51
Downstream: 1.304 Mbps
Upstream: 708.2 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 3.3 dB / 5.4 dB
Line attenuation (Down/Up): 65.1 dB / 42.0 dB
Output power (Down/Up): 15.5 dBm / 12.6 dBm
FEC Events (Down/Up): 425378 / 39
CRC Events (Down/Up): 12 / 46
HEC Events (Down/Up): 15 / 19
Error Seconds (Local/Remote): 11 / 11
29 REPLIES 29
Message 2 of 30
Re: broadband speed problems
are you connected to the test or master socket?  do you have other sockets apart from the master?
is the last set of stats new or can you post the current adsl stats please
try quiet line test  dial 17070 option 2  should hear nothing and best with corded phone  if cordless dull hum normal
Don01
Message 3 of 30
Hi sorry I ment to put all that info in. I only have the one master socket and I,m connected to the test port inside the socket as this was requested by bt so its been in there the last 2 weeks
edit- also there was noise on the line this was reported bt the bt person I was speeking to as she could hear it, but this has now been closed which said they could not fined any fault with the noise on the line.
Also yesterday when they done test they said there was a fault on line for broadband
Message 4 of 30
quiet line test?
new stats later?
Don01
Message 5 of 30
Just edited my last post to show line noise, I'll do new stats the now and post in a few minutes
Message 6 of 30
As imjolly has posted could you also try the quiet line test and post the results
Don01
Message 7 of 30
Hi, not sure how I would do the quiet line test and get the results to post as I thought it was just a number you called?
Here's new stats from a few minutes ago Thanks for helping 🙂
ADSL Line Status
Connection time: 0 days, 16:53:28
Downstream: 1.413 Mbps
Upstream: 636.2 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 10.9 dB / 5.9 dB
Output power (Down/Up): 15.7 dBm / 12.7 dBm
FEC Events (Down/Up): 10782549 / 6467
CRC Events (Down/Up): 456 / 153
HEC Events (Down/Up): 413 / 209
Error Seconds (Local/Remote): 43092 / 4445
Message 8 of 30
you dial 17070 select option 2 you should hear no noise any noise heard should be reported to BT Faults on 151 after any problem is resolved your broadband should improve  just post back what you heard
Message 9 of 30
stats look like there is noise on your line  try quiet line test
Don01
Message 10 of 30
I can hear a faint crackling noise, is that normal?
