gmac123
Message 1 of 6
broadband speed
can anybody shed some light as to why my line which according to bt supports up to 24meg i seem to be capped at a speed of 8meg according to bt that is the fastest they can supply to me. i live 200yds from the exchange am on an exchange only line so no street cabinet to slow things down.
5 REPLIES 5
Message 2 of 6
Re: broadband speed
check your exchange - is it 21CN enabled
check exchange
cam you post stats from your router
can you enter your phone number and post results  please delete number before posting https://www.btwholesale.com/includes/adsl/main.html
gmac123
Message 3 of 6
Re: broadband speed
exchnge is 21cn enabled
dont know how to post results from line checker
but it says wbc adsl2+ downstream rate up to 8 mbps downstream range 3.5 to 17.5mbps
Message 4 of 6
Re: broadband speed
just copy and paste the results into the reply box
Message 5 of 6
Re: broadband speed
Can you post adsl stats from your router
Message 6 of 6
Re: broadband speed
If you are only 200yds from exchange then speeds from the checker appear low
