simon3142
Message 1 of 4
bt homehub doesn't play nice with my Epson xp305 printer
I have an Epson XP305 printer/scanner set up for WiFi and when I use the BT homehub4, the printing is very slow to start and when I try to use the scanner I have a 50:50 chance that the scanner program will not open as it can't find the scanner. Usually it will work at the scond try.
This doesn not happen with the Netgear 2200 router. The printing starts in less than half the time and the scanner works every time.
I can't see any reason why this should happen, I wonder if anyone has any suggestions? I will try asking Epson as well.
I have Windows 7 64 bit and an old dell XPs 8100.
3 REPLIES 3
Message 2 of 4
Re: bt homehub doesn't play nice with my Epson xp305 printer
from memeory the hh4 is dual band combined so have you tried separating the bands and then connect printer to 2.4ghz band and see if that helps  many devices don't like the bands combined
simon3142
Message 3 of 4
I wondered about the about the dual band issue, but wasn't sure what to do about it except turning off the other band. How to do you sepate the bands?
simon3142
Message 4 of 4
It's OK, I found a BT help page on this. Thanks
