jfrice
Message 1 of 9
bt line box broadband speed issues
At the test socket on my bt line box I am getting 4.5 Mb/s speed.
At the linebox faceplate outer socket I get 2.0 Mb/s, a speed drop of 2.5 on the faceplate itself. Can anyone explain why this could happen please ?
8 REPLIES 8
Message 2 of 9
Re: bt line box broadband speed issues
Faulty faceplate or internal wiring problems - any extension wiring connected to back of front plate?
Moderator
Moderator
Message 3 of 9
Hi @jfrice,
@imjolly is correct. This sounds like a faulty face plate. Have you managed to get a replacement? Can you let us know how you're getting on?
Cheers
David
Distinguished Guru
Message 4 of 9
Hi.
As Imjolly suggests if there is wiring attached to the front plate then that would be the problem.
Very unlikely to be a front plate problem.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Moderator
Moderator
Message 5 of 9
Hi @jfrice,
Did you replace the face plate and did it sort the problem. Can you let us know if you've managed to resolve this?
Cheers
David
jfrice
Message 6 of 9
Yes agree. Bought a replacement faceplate as well as a BT i filter which I only discovered existed by chance and this was developed by BT to filter out the bell wire signal at the line box itself which apparently interfears with the network downstream of the linebox and the result is to increase the broadband speed. The filter plugs in between the linebox backbox and the faceplate, no connections necessary.
Result without changing the old faceplate was surprising, the speed as measured at the broad band router went up from 1.462Mb/s to 3.815Mb/s an excellent result for £5.99 !!!
Having maintained this speed to date I am going to renew the faceplate next and see if a further improvement can be achieved. this maybe as good as it gets as I am getting 4.085 at the test socket so cant beat that anyway.
I would recommend anyone with speed issues to fit the BT Broadband i plate anyway. Check it out on Amazon.
Message 7 of 9
personally I would and did when on adsl just remove the bellwire from termianl 3 in all my sockets and that was better than the iplate.  still if it works for you that is all that counts
jfrice
Message 8 of 9
Thanks for your help
John25Roberts
Message 9 of 9
Surprised those iPlates are still out there. All Openreach Branded NTEa's have Bell Wire Filters built in and the ones made in the past year or so have also had the Surge Protector removed as that also causes problems.
As a rule most Openreach Engineers, the broadband trained ones anyway don't generally connect the Bell Wire as a rule now unless the EU needs it, eg they have an old fashioned corded phone on a LJU...
