Message 1 of 29
download speed halved.
Hello, been having a few issues with my download speed the past few weeks, Upload and download were stable for months before hand however the past few weeks the hub has been dropping once or twice a day. It has now stopped dropping however the download speed seems to be stuck at half of what we were getting before, This normally would not be much of an issue but because we get such a bad download speed it is really affecting things and causing issues doing almost anything except loading web pages.
Quite some time ago we had the download speed brought up from 448 to around 900 which helped things but now its done the same thing to the download.
1. Product name:BT Home Hub
2. Serial number:+068343+NQ41710626
3. Firmware version:Software version 4.7.5.1.83.8.264 (Type A) Last updated 05/07/19
4. Board version:BT Hub 5A
5. DSL uptime:2 days, 00:05:48
6. Data rate:975 / 1152
7. Maximum data rate:959 / 2204
8. Noise margin:5.9 / 13.9
9. Line attenuation:34.6 / 62.7
10. Signal attenuation:34.2 / 56.8
11. Data sent/received:539.3 MB / 5.0 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-W82G
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-W82G
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:40:f2:01:15:e4:06
24. VPI/VCI:0 / 38
25. Modulation:G.992.5 Annex A
26. Latency type:Interleaved
27. Software variant:AA
28. Boot loader:1.0.0
28 REPLIES 28
Message 2 of 29
Re: download speed halved.
all your drops in connection and possibly manual resets trying to restore speed have resulted in your connection ending up in a banded profile  this should release in 7/10 days provided connection remains stable with no drops  noise margin should start to reduce with corresponding increases in down speed getting back to your previous speed
if no improvement after that time post back and can see if mods will help
Message 3 of 29
Okay we will wait and see if it fixes itself, I haven't reset the router in a long time as I found out it was having the opposite effect. Fingers crossed as its already a slow enough line!
Message 4 of 29
Sadly another drop... attached part of the log just incase it has anything useful, guess this will set back the waiting time for it to unlock.
never seen the connection request line before.
02:17:43, 15 Nov.( 18.180000) System start
02:16:50, 15 Nov.(217425.030000) PPP LCP Send Termination Request [User request]
02:16:49, 15 Nov.(217423.150000) The system is going DOWN for reboot.
02:16:49, 15 Nov.(217423.150000) OpenRG is going for reboot by IPC command
02:16:44, 15 Nov.(217418.150000) OpenRG will go down for reboot in 5 seconds
01:56:39, 15 Nov.(216213.310000) CWMP: session completed successfully
01:56:36, 15 Nov.(216210.690000) CWMP: Set Parameter by TR069 Success
01:56:35, 15 Nov.(216209.980000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
01:56:33, 15 Nov.(216207.450000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
01:56:33, 15 Nov.(216207.450000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
01:56:32, 15 Nov.(216206.720000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
01:56:31, 15 Nov.(216205.890000) CWMP: session completed successfully
01:56:29, 15 Nov.(216203.370000) CWMP: Set Parameter by TR069 Success
01:56:28, 15 Nov.(216202.900000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
01:56:24, 15 Nov.(216198.260000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
01:56:24, 15 Nov.(216198.260000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
01:56:23, 15 Nov.(216197.540000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
Moderator
Moderator
Message 5 of 29
Hi @Alex_7753 and thanks for posting.
I'm sorry you're having problems with the connection. Have you checked for any noise on the line? If not can you try that by dialling 17070 option 2 on a corded phone?
Cheers
David
Message 6 of 29
Just done the quite line again, nothing wrong that I can hear. Broadband has been fine for months then only lately just started slowing down. Not too sure if you can reset the line out of banding and back to fast latency?
Message 7 of 29
Any reset is pointless until you are able to find the cause of the drops in connection and fix it
Message 8 of 29
Fair enough, not too sure what else to check, only thing that stood out to me was the log when it disconnected that I posted before, not 100% sure what it means. Faceplate and filter is only a few months old after the last one was damaged by lightening, openreach engineer put in new socket, filtered faceplate and a new HH4.
Cant seem to find any re-occurring problem every time it disconnects the log is different. I used to have a netgear router before it failed, not sure if I should look into a new router to see if it’s any better? Don’t want to go spending money if I don’t have too since the hub was working perfectly fine before.
Message 9 of 29
Even if you have a new faceplate I would try connecting to test socket with a filter and see if that helps stabilise your connection.  Without a stable connection you are not going to get improved speed and if your line was reset and still unstable you would be back where you are in a week or so
when in test socket I would check that there is no dial tone at any extension socket as that would be a problem
if that does not improve then you are going to need an engineer visit
Message 10 of 29
Been using the test socket since the last drop, dropped again about 5 hours ago, down speed has increased from;
Down Rate=1152Kbps, Up Rate=983Kbps; SNR Margin Down=12.7dB, Up=5.7dB
to;
Down Rate=1215Kbps, Up Rate=971Kbps; SNR Margin Down=15.8dB, Up=6.1dB
here is the log from the disconnected, (not sure if this means it is out of banding now since the download increased just  tad)
06:16:10, 19 Nov.(359916.800000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
06:16:10, 19 Nov.(359916.790000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
06:16:02, 19 Nov.(359909.110000) WAN operating mode is ADSL
06:16:02, 19 Nov.(359909.110000) Last WAN operating mode was ADSL
06:16:01, 19 Nov.(359907.820000) PPP IPCP Receive Configuration ACK
06:16:01, 19 Nov.(359907.810000) PPP IPCP Send Configuration Request
06:16:01, 19 Nov.(359907.810000) PPP IPCP Receive Configuration NAK
06:16:01, 19 Nov.(359907.800000) PPP IPCP Send Configuration ACK
06:16:01, 19 Nov.(359907.800000) PPP IPCP Receive Configuration Request
06:16:01, 19 Nov.(359907.320000) PPP IPCP Send Configuration Request
06:15:59, 19 Nov.(359905.700000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=1215Kbps, Up Rate=971Kbps; SNR Margin Down=15.8dB, Up=6.1dB
06:15:59, 19 Nov.(359905.680000) CHAP authentication successful
06:15:59, 19 Nov.(359905.620000) CHAP Receive Challenge
06:15:59, 19 Nov.(359905.620000) Starting CHAP authentication with peer
06:15:59, 19 Nov.(359905.610000) PPP LCP Receive Configuration ACK
06:15:59, 19 Nov.(359905.610000) PPP LCP Send Configuration Request
06:15:59, 19 Nov.(359905.610000) PPP LCP Receive Configuration Reject
06:15:59, 19 Nov.(359905.600000) PPP LCP Send Configuration ACK
06:15:59, 19 Nov.(359905.600000) PPP LCP Receive Configuration Request
06:15:59, 19 Nov.(359905.530000) PPP LCP Send Configuration Request
06:15:56, 19 Nov.(359902.530000) PPP LCP Send Configuration Request
06:15:53, 19 Nov.(359899.530000) PPP LCP Send Configuration Request
06:15:50, 19 Nov.(359896.530000) PPP LCP Send Configuration Request
06:15:47, 19 Nov.(359893.530000) PPP LCP Send Configuration Request
06:15:44, 19 Nov.(359890.530000) PPP LCP Send Configuration Request
06:15:37, 19 Nov.(359883.960000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=1215Kbps, Up Rate=971Kbps; SNR Margin Down=15.8dB, Up=6.0dB
06:15:37, 19 Nov.(359883.960000) ATM over DSL is up
06:15:16, 19 Nov.(359862.400000) CWMP: session closed due to error: Could not resolve host
06:15:15, 19 Nov.(359861.250000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
06:15:15, 19 Nov.(359861.240000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
06:14:44, 19 Nov.(359830.580000) CWMP: session closed due to error: Could not resolve host
06:14:41, 19 Nov.(359827.840000) ATM over DSL is down after 5995 minutes uptime
06:14:41, 19 Nov.(359827.840000) ETHoA is down after 5995 minutes uptime
06:14:40, 19 Nov.(359826.630000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
06:14:40, 19 Nov.(359826.620000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
06:14:39, 19 Nov.(359825.900000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
06:14:38, 19 Nov.(359824.790000) PPPoA is down after 5994 minutes uptime [Disconnected]
06:09:18, 19 Nov.IN: BLOCK [16] Remote administration (TCP [82.102.173.73]:41313-​>[86.130.187.87]:8443 on ppp0)
05:59:52, 19 Nov.IN: BLOCK [16] Remote administration (TCP [45.143.220.23]:41288-​>[86.130.187.87]:80 on ppp0)
05:53:37, 19 Nov.IN: BLOCK [16] Remote administration (TCP [79.143.188.161]:61000-​>[86.130.187.87]:80 on ppp0)
05:44:57, 19 Nov.IN: BLOCK [16] Remote administration (TCP [178.156.83.159]:33465-​>[86.130.187.87]:8080 on ppp0)
05:44:22, 19 Nov.IN: BLOCK [16] Remote administration (TCP [82.120.89.59]:48253-​>[86.130.187.87]:22 on ppp0)
05:41:33, 19 Nov.IN: BLOCK [16] Remote administration (TCP [61.177.172.128]:50622-​>[86.130.187.87]:22 on ppp0)
05:37:26, 19 Nov.IN: BLOCK [16] Remote administration (TCP [223.81.4.22]:54146-​>[86.130.187.87]:8080 on ppp0)
05:34:05, 19 Nov.IN: BLOCK [16] Remote administration (TCP [167.114.155.235]:56479-​>[86.130.187.87]:22 on ppp0)
05:32:48, 19 Nov.(357315.050000) CWMP: session completed successfully
05:32:48, 19 Nov.(357314.850000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
05:32:45, 19 Nov.(357311.900000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
05:32:45, 19 Nov.(357311.900000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
05:32:45, 19 Nov.(357311.200000) CWMP: Initializing transaction for event code 2 PERIODIC
