lastofthetimelords
Message 1 of 25
dropped connection
had issues with connection since joining BT in april, awful speed and connection compared to my previous isp O2, connected to master socket with a filtered faceplate, quiet line test is fine all be it with a cordless phone but i am still getting several disconnections daily. when the connection works it is ok, but i am really fed up with it know, does anyone know if i am able to leave my contract without penalty? as the service being given to me is not acceptable
current stats
Connection Information
Line state:Connected
Connection time:0 days, 00:17:09
Downstream:4.188 Mbps
Upstream:864 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.3 dB / 7.0 dB
Line attenuation (Down/Up):51.9 dB / 34.5 dB
Output power (Down/Up):18.3 dBm / 12.4 dBm
FEC Events (Down/Up):2027 / 325
CRC Events (Down/Up):1 / 5
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):4 / 43
Error Seconds (Local/Remote):1004 / 23
24 REPLIES 24
Message 2 of 25
Re: dropped connection
no you cannot cancel your contract without penalty
the cause of the disconnections must be found first as changing isps will not resolve the problem have you tried connecting directly to the test socket to eliminate internal wiring issues
Message 3 of 25
the last time you posted I asked you to connect to test socket and repost stats and you were about and repost stats.
now we're back with same problem and same request
lastofthetimelords
Message 4 of 25
Connection time:0 days, 00:03:21
Downstream:4.216 Mbps
Upstream:864 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):2.8 dB / 7.5 dB
Line attenuation (Down/Up):51.8 dB / 34.5 dB
Output power (Down/Up):18.4 dBm / 12.4 dBm
FEC Events (Down/Up):19418 / 335
CRC Events (Down/Up):5 / 1
HEC Events (Down/Up):56 / 1
Error Seconds (Local/Remote):1049 / 36
lastofthetimelords
Message 5 of 25
will post again in 1 hour
lastofthetimelords
Message 6 of 25
adsl filtered faceplate v1.0 fitted maybe 3/4 years ago is it worth investing in a new one?
Message 7 of 25
before going to that expense I wiuld connect your router to the test socket via a filter and repost the stats.  if that helps your connection then maybe it is time to replace SSFP
lastofthetimelords
Message 8 of 25
this is current stats connected to test socket
ADSL Line Status
Connection time:0 days, 00:55:29
Downstream:4.091 Mbps
Upstream:864 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):2.3 dB / 7.4 dB
Line attenuation (Down/Up):51.8 dB / 34.6 dB
FEC Events (Down/Up):1201648 / 8415
CRC Events (Down/Up):67 / 0
HEC Events (Down/Up):311 / 0
Error Seconds (Local/Remote):1103 / 36
Message 9 of 25
stats similar so now leave connected and see if that helps stabilise your connection
lastofthetimelords
Message 10 of 25
will see how it goes, not holding my breath though
