lastofthetimelords
Message 11 of 25
Re: dropped connection
dropped connection 2 hours ago or so, why does it keep dropping
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 02:32:44
Downstream:3.875 Mbps
Upstream:864 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):3.5 dB / 7.6 dB
Line attenuation (Down/Up):51.8 dB / 34.5 dB
Output power (Down/Up):18.1 dBm / 12.4 dBm
FEC Events (Down/Up):1136414 / 131814
CRC Events (Down/Up):131 / 131
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):744 / 258
Error Seconds (Local/Remote):94 / 63
lastofthetimelords
Message 12 of 25
I had a phone call @ 09.31 am this morning and this is about the time that my connection dropped, is there chance that this caused disconnnnection, never happened with previous isp, could the hub be faulty?
Message 13 of 25
if you are still connected to the test socket then phone home from mobile and see if conenction drops?  does it drop if you make a call?
lastofthetimelords
Message 14 of 25
still connected to test socket, i've just dialled out then called in on my mobile shortly after i had no broadband
so what's the answer?I never had any trouble like this with O2 my previous isp, I am sorry I left them
any suggestions, can the mods help?
current stats after disconnect
ADSL Line Status
Connection time:0 days, 00:04:57
Upstream:864 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.8 dB / 7.7 dB
FEC Events (Down/Up):1550535 / 147230
CRC Events (Down/Up):138 / 143
HEC Events (Down/Up):807 / 367
Error Seconds (Local/Remote):100 / 71
Message 15 of 25
I suggest you contact the forum mods to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
lastofthetimelords
Message 16 of 25
I have contacted the Mods, really hope they can help, lots of people said I was foolish coming to BT Broadband, They're certainly not the cheapest out there, I'm a firm believer in, you get what you pay for, in my case all I seem to be getting is grief, thanx for your assistance
lastofthetimelords
Message 17 of 25
seems to be after incoming call, about 1 min 30 seconds after an incoming call from my mobile  there is loss of connection, yet quiet line test there is no crackles or noise
Message 18 of 25
it could be a high resistence fault but that normally disconnects your broadband when the phone rings not well after the call has ended.  still contacting mods will help get problem fixed - probably engineer visit required
lastofthetimelords
Message 19 of 25
After monitoring today, it's definitely getting knocked off when I receive an incoming call, it's just happened again
just waiting on the mods contacting me
current stats
ADSL Line Status
Connection time:0 days, 00:06:57
Downstream:2.654 Mbps
Upstream:864 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):10.8 dB / 7.9 dB
Line attenuation (Down/Up):51.4 dB / 34.5 dB
Output power (Down/Up):16.9 dBm / 12.4 dBm
FEC Events (Down/Up):269940 / 124410
CRC Events (Down/Up):312 / 341
HEC Events (Down/Up):1182 / 942
Error Seconds (Local/Remote):103 / 150
Message 20 of 25
as you have already contacted the mods then just a matter of waiting until mods contact you
