razten
Message 1 of 16
have this problem over a month now
Afternoon everyone,
Where should I start..
About a month ago my hub started resetting itself whenever I used internet, i spoke to numerous amount of people over at the call centre and about 2 weeks after calling them nearly every day they sent openreach engineer over to my house to check whats going on. He did what he had to do inside my house and outside my house, then he did some tests which all said "passed", but hey after the visit i went straight on my computer and checked the speeds which were at about 1mb at the time which still are not good enough considering i had 6-8mb about 3 months ago, anyway back on the subject i contacted bt yet again and they said the line needs to be running few days for the connection to stabilise. A week of waiting and still nonthing speeds the same and my hub was still resetting itself but not as often as it used to. After a week I decided im not going to bother with those useless people in the call centre so I emailed bt and started to explain my problem all over again, first they sent an engineer to my exchange to see whats going on there, still nothing improved after that. They then decided that they should send an engineer again which came to my house yesterday and replaced the master socket and also did other things which i didnt see. He then like the first engineer did some tests and he said that the speed hes getting from the master socket is 9.7mb i was all excited that i finally got back speeds i used to have about 3months ago but hey, went on the computer straight away after the visit and the speeds were at 500kb/s. I had an idea today that maybe i should bring my computer downstairs with the hub and connect it to the master socket but still nothing.. same speeds and the hub is still resetting from time to time, if i counted correctly the hub resetted 7 times today and 4/7 of them resets the hub didnt connect to the broadband for about an hour and on one reset it didnt connect for 4 hours the rest connected in about a minute. This is really going beyond a joke now, really unuhappy with the whole situation which i repeat had for over a MONTH now. Im thinking of changing to another ISP and as bt said if i change from bt to any isp the problem will still remain id prefer to talk to normal people and not the callcentre which as a matter of fact everybody knows is useless and you can barely understand what they are trying to say due to obvious reasons.
                                         TEST
Quite line is fine not much noise even though im using a cordless phone.
Connection information
Line stateConnected
Connection time0 days, 0:57:48
Downstream1,151 Kbps
Upstream708 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)25.0 dB / 8.8 dB
Line attenuation (Down/Up)42.5 dB / 21.8 dB
Output power (Down/Up)20.1 dBm / 12.4 dBm
FAQ
Results Image not loaded
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
Download Speed
622 Kbps
0 Kbps1000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 622 Kbps
 For your connection, the acceptable range of speedsis 400-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :1148 Kbps(DOWN-STREAM), 708 Kbps(UP-STREAM)
 IP Profile for your line is - 750 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 11.79:25.54:62.8 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test:  -provides background information.
Upload Speed
572 Kbps
0 Kbps708 Kbps
>Upload speed achieved during the test was - 572 Kbps
 Upstream Rate IP profile on your line is - 708 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
http://www.speedtest.net/result/1221794792.png
Thank you to anyone who will bother to read my rant, but hopefully im going to get my message across now....
15 REPLIES 15
Message 2 of 16
Re: have this problem over a month now
can you go back to the adsl stats and post the rest of the information - may have to 'show detail' to get errors
as you have taken the trouble to move everything downstairs did you try the test socket instead of the master as that will eliminate any noise from your extension wiring?
razten
Message 3 of 16
rest of the stats :
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)21.9 dB / 8.3 dB
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)11189 / 22
CRC Errors (Down/Up)8 / 2147480000
HEC Errors (Down/Up)nil / 878043
Error Seconds (Local)5
razten
Message 4 of 16
oh and no i havent tried test socket dont even know what that is to be honest with you
Message 5 of 16
if the engineer replaced the master socket the bottom half will detach and the test socket is behind. test socket is a direct connection to the exchange and eliminates extension wiring.  your extens wiring is attached to the back of the bottom half so if you do remove it just remember not to just pull.
or did engineer replace with filter faceplate - 2 sockets on front - 1 for phone and 1 for broadband?
razten
Message 6 of 16
my socket looks the same it still has paint on sides that means he must have only replaced the faceplate but as far as i can see it looks like the old faceplate but with bt logo and some writing saying bt open reach, theres only one socket at the front and thats for the filter
Message 7 of 16
ok really surprised he didn't replace with a new NTE5 where the face is split and bottom half can be removed.  if not then you don't have a test socket if that is the master
razten
Message 8 of 16
Oh, sorry i forgot to tell you in the last post that i can unscrew the bottom half, and so i did just and i can see that on the right hand side there is another socket there for an adsl filter, what do you suggest i should do ?
Message 9 of 16
great that is the test socket.  plug filter in and then connect hub and phone if you want as no other socket in your home will work while you are connected to the test socket.
once connected can your post the full adsl stats from the hub
razten
Message 10 of 16
grrrr, so i have to take my computer downstairs again to check the adsl settings on the test socket  ?
