razten
Message 11 of 16
Re: have this problem over a month now
adsl setting on the test socket :
Connection information
Line stateConnected
Connection time0 days, 0:02:33
Downstream1,151 Kbps
Upstream708 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)29.0 dB / 8.3 dB
Line attenuation (Down/Up)42.0 dB / 21.4 dB
Output power (Down/Up)20.1 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)12 / 0
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 878511
Error Seconds (Local)0
Message 12 of 16
I know the stats don't look any better but you should now manage a more stable connection which is needed as I think due to all the previous disconnection problems you have had you are now in a banded profile.  This is done automatically by the exchange on 21CN to try and stabise your line.  If you can maintain a stable connection 24/7 for 3/5 days then you should get out the banded profile and back to a normal speed which based on your attenuation is about 8mb as shown here http://www.kitz.co.uk/adsl/max_speed_calc.php
I don't know how easy that is for you if pc is normally upstairs.  once speed back you can then move back and hope it stays at same speed as test socket
razten
Message 13 of 16
thanks for everything Jolly, i will wait out 3/5 days on the test socket as you said and will come back here to post results.
Message 14 of 16
great and I hope next stats looks a lot better  patience but it is hard:smileywink:
razten
Message 15 of 16
patience.. nice 1 already been through a month of this bs from bt
Message 16 of 16
you can always try the mods who are BT employees http://bt.custhelp.com/app/contact_email/c/4951
may take a few days before they contact you
