19NicK64
Message 1 of 11
high latency / interleaved
I am hoping that there is a BT tech mod hear that is able to turn my Interleaved off.I have tried calling the BT tech but they did not understand what I was requesting.
as i play online gameswhich need a low latency
thank you for a swift reply
1. Product name: BT Home Hub
2. Serial number: +068340+NQ43040840
3. Firmware version: Software version 4.7.5.1.83.8.130.1.17 (Type A) Last updated 23/10/14
4. Board version: BT Hub 4A
5. ADSL uptime: 1 days, 16:09:06
6. Bandwidth: 352 / 3712
7. Data sent/received: 875.7 MB / 2.4 GB
8. Broadband username: bthomehub@btbroadband.com
9. BT FON: Yes
10. 2.4 GHz Wireless network/SSID: BTHub4-7JZN
11. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled
12. 2.4 GHz Wireless security: WPA and WPA2
13. 2.4 GHz Wireless channel: Automatic / 1
14. 5 GHz Wireless network/SSID: BTHub4-7JZN
15. 5 GHz Wireless connections: Enabled (802.11 n 40 MHz (Recommended)) 20/40 MHz, WPS enabled
16. 5 GHz Wireless security: WPA2
17. 5 GHz Wireless channel: Automatic / 40
18. Firewall: Default
19. MAC Address: c8:91:f9:41:c3:2e
20. VPI/VCI: 0 / 38
21. Modulation: G.992.1 Annex A
22. Latency type: Interleaved
23. Software variant: -
24. Boot loader:
10 REPLIES 10
Message 2 of 11
Re: high latency / interleaved
your connection time is only 1+ days is that due to manual reset or router dropping connection?
you cannot turn interleaved off but you can get latency changed to fast which is preferred setting for gamers.  however this may make your line less stable and if you strat dropping conenction then the DLM will put your line back on interleaved
19NicK64
Message 3 of 11
i had a  power outage due to  bad weather
i know i can have "fast" but getttting them to understand a word i say is another thing.
can a tech or mod   help me here please
Message 4 of 11
you must be able to show 3days + stable connection before the mods will undertake a move to fastpath
19NicK64
Message 5 of 11
5. ADSL uptime: 4 days, 02:27:19
7. Data sent/received: 1.9 GB / 770.7 MB
9. BT FON: Yes
20. VPI/VCI: 0 / 38
24. Boot loader:
Can i get some help now please ........
Message 6 of 11
As you now have 4days the mods will help you get latency changed to fast. They will post a contact us link.
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
Moderator
Moderator
Message 7 of 11
Hi 19NicK64,
Welcome to the community forum. I'll be able to change interleaving to "fast" for your connection. Please send me in your details using the "Contact The Mods" link found in my email.
PaddyB
19NicK64
Message 8 of 11
i think i  have done this  thanks for help
19NicK64
Message 9 of 11
THANKS
intreleaved now on FAST
Message 10 of 11
glad all now resolved for you
