markythesparky
Message 1 of 38
internet keeps dropping out
what is acceptable for the number of drop outs per day
i have been having a ongoing problem for about a year now i have had engerneers out 4 times ,a new main socket, 5 new hubs and the problem is still happening it will sometimes stay connected for a day or two and then start dropping 3 or 4 times a day the longest it has stayed connected is 11 days and the most it has dropped out is 15 times in one day tried the online help and the phone line help but all they seem to do is send a new hub getting fedup with bt.
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:33:13
Downstream:19.32 Mbps
Upstream:1.255 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):4.1 dB / 8.5 dB
Line attenuation (Down/Up):21.5 dB / 13.1 dB
Output power (Down/Up):17.6 dBm / 11.9 dBm
FEC Events (Down/Up):46693 / 0
CRC Events (Down/Up):30 / 0
37 REPLIES 37
Message 2 of 38
Re: internet keeps dropping out
Is there any noise on your phone line when the dropouts occur?
markythesparky
Message 3 of 38
i have not heard anything
Message 4 of 38
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
markythesparky
Message 5 of 38
no noise on line still dropping off line
Moderator
Moderator
Message 6 of 38
Hi @markythesparky,
Thanks for posting. Can you try connecting to the test socket behind the master faceplate and let us know if the connection still drops? If it does then we'll need to take a closer look at that for you.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
markythesparky
Message 7 of 38
after all the trouble i have had it is allways connected to the test socket just had 1day 20hrs connected then 2 drop outs
Moderator
Moderator
Message 8 of 38
Hi @markythesparky Sorry about the drop outs on your broadband connection.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Community ModeratorJohnC
Kudos”Kudos”
markythesparky
Message 9 of 38
sent info
Moderator
Moderator
Message 10 of 38
Hi @markythesparky,
Thanks for confirmimg that. We're busier than usual so it's taking longer than expected to reply but once you submit the details we'll get to you in turn.
Cheers
David
Kudos”Kudos”
