Xbox-Legend
Newbie
Message 1 of 5
is this acceptable noise? seem to be very laggy on xbox one,
DSL Link Up: Down Rate=7424Kbps, Up Rate=448Kbps; SNR Margin Down=6.1dB, Up=21.0dB
Tags (3)
4 REPLIES 4
Message 2 of 5
Re: is this acceptable noise? seem to be very laggy on xbox one,
Yep, pretty much perfect.
Message 3 of 5
Are you playing with a wired or wireless connection?
Xbox-Legend
Newbie
Message 4 of 5
wired, wired all the way, its a long Ethernet cable 15m but I didn't think the length of a Ethernet cable would effect it much.
thanks for the quick reply 😄
Xbox-Legend
Newbie
Message 5 of 5
just moved router closer too the xbox one, using a shorter Ethernet cable now about 3M and latency is 180ms 0% packet loss MTU 1480
