Message 1 of 21
leaving bt
hi was wondering if its possible to exit contract early if the bt service is only giving me under 10mb connection which struggles to play netflix sometimes  without incurring the exit fee?
20 REPLIES 20
Expert
Message 2 of 21
Re: leaving bt
What speeds did you sign up to ? if you're above the minimum guarantee then no you can't leave penalty free, if you're under the minimum guarantee then you have to allow BT the chance to restore it, if not then leaving becomes an option.
Check your past order confirmation to see what your minimum guaranteed speed is.
Message 3 of 21
Re: leaving bt
@woolfman
Welcome to this user forum. Unless BT say they cannot fix your speed fault, then you cannot exit without charge.
What connection speed were you promised when your contract started, and when did your contract start?
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Message 4 of 21
Re: leaving bt
on the bt speed checker it says i have 9mb and the minimum speed they guarantee is 2mb download the maximum im able to download at is 1.1mbs
Message 5 of 21
Re: leaving bt
Telephone Number on Exchange NEWQUAY is served by Cabinet 6
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsADSLOther Offerings
Availability Date
Premise environmentStatus
WBC ADSL 2+Up to 16--14.5 to 18Available----
WBC ADSL 2+ Annex MUp to 16Up to 1.514.5 to 18Available----
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate2----Available----
Max Observed Downstream Speed (Mbps)11.22
Max Upstream Observed Speed (Mbps)1.22
Observed Date2019-11-09
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date04-12-2019
Message 6 of 21
Re: leaving bt
i started the contract in march at another address with 40 mb fibre then moved to central newquay and they havent enabled fibre here and have no plans to do so
Expert
Message 7 of 21
Re: leaving bt
If you're downloading at 1.1 mbs then your connection speed is 8.8 mbps, which is close to estimate and above the minimum guarantee.
Message 8 of 21
Re: leaving bt
Are you sure you are not confusing megabytes/s with megabits/s?
Please could you post the results from the BT Wholesale Performance Checker.
http://speedtest.btwholesale.com/
Message 9 of 21
Re: leaving bt
Download Speed (Mbps): 7.73
Upload Speed (Mbps) : 0.84
Ping Latency (ms): 108
Message 10 of 21
Re: leaving bt
Download Speed (Mbps): 8.66
Upload Speed (Mbps) : 0.85
Ping Latency (ms): 28
