Message 11 of 21
Re: leaving bt
as you can see it varies all the time
Message 12 of 21
Re: leaving bt
Did you run that test with an Ethernet connected device, or was it using wireless?
Which BT Home hub are you using?
Message 13 of 21
Re: leaving bt
with ethernet and smart hub 6
Message 14 of 21
Re: leaving bt
i always have my main comp on wired connection as i game online and need best connection possible
Message 15 of 21
Re: leaving bt
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Please can you provide the connection information from the home hub.
If you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
Message 16 of 21
Re: leaving bt
BT Hub 6A
Serial number:
+084318+NQ84875011
Firmware version:
SG4B1000E01E
Firmware updated:
26-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
6 Days, 1 Hours 17 Minutes 19 Seconds
Data rate:
1.21 Mbps / 11.27 Mbps
Maximum data rate:
1212 / 11656
Noise margin:
5.6 dB / 5.2 dB
Line attenuation:
36 dB
Signal attenuation:
15.5 dB / 36 dB
VPI / VCI:
0/38
Modulation:
G_992_5_ANNEX_A
Latency type:
Fast Path
Data sent / received:
82553 MB Uploaded / 36034 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-HW9N
2.4 GHz wireless channel:
Channel 11
5 GHz wireless network name:
BTHub6-HW9N-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
30:24:78:C5:BA:03
Software variant:
Boot loader:
9.2.0
Message 17 of 21
Re: leaving bt
Connection speed is fine. Was there any noise on your phone line, as that would cause errors which would reduce your download speed?
Message 18 of 21
Re: leaving bt
nope no noise on line
Message 19 of 21
Re: leaving bt
You actual connection speed does seem lower than it says on the availability page, but the estimate for your line attenuation is about right, so maybe there is an issue with your internal wiring?
Estimation of your maximum rate adaptive adsl speed
Downstream
Attenuation
dB Approx
Line Length
km
dslMAX (20CN) kbps IP Profile kbps
BT 21CN WBC
& adsl2+
adsl2+ (LLU) kbps Throughput kbps
What does your master phone socket look like, and have you any extensions?
Or
Message 20 of 21
Re: leaving bt
just had latest master socket installed and all extensions removed
