Message 21 of 21
Re: leaving bt
@woolfman wrote:
just had latest master socket installed and all extensions removed
Then the figures I posted from the Kitz site, would indicate your connection speed is about right.
Variations in download speed could simply be due to network congestion, as you share you connection in the exchange, with other users.
If you are connected to the older DSLAM as opposed to the 21cn MSAN, then this is likely to cause more variation in speed.
Either way, there is plenty of bandwidth for Netflix, unless the download speed is dropping in the evening.
I would try a few speed tests at different times of the day, and see if its slower in the evening, as you may be on a congested path which needs upgrading.
