Message 11 of 20
Re: low line speed with high CRC/HEC and error seconds - faulty line?
you need rein engineer with specilaised equipment
Message 12 of 20
which the mods can arrange
waiting_for_baudot
Message 13 of 20
OK, seven working days without any contact from the mods. I understand they are busy but I don't know if my original email reached their inbox so I'd like to re-submit the request.
However, I see as of yesterday that the old contact link is no longer working so could I please request again some help from the mods? The short summary is that I appear (from upload speed etc) to be stuck on an old fixed 2Mb product and have not been migrated to ADSLmax.
I don't think there is any other solution to my problem apart from the mods, the normal BT support route has proved fruitless and I can't upgrade or cancel the account and move to a different ISP as the account info shows that I am connected to ADSLmax even though I'm not...
Help!
Message 14 of 20
can you post the current adsl stats.
the mods will get back to you and may read your recent post and contact you
Message 15 of 20
Moderator
Moderator
Message 16 of 20
Hi Waiting_for_baudot,
Sorry you haven't had a reply yet I can see your email is in the queue and I'll get one of my colleagues to reply to you as soon as they can.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
waiting_for_baudot
Message 17 of 20
Thanks!
Message 18 of 20
plesae keep thread updated - always like to see outcome
waiting_for_baudot
Message 19 of 20
Thanks to some excellent support from the mods, the fixed rate problem was corrected recently and the line has now moved to ADSLmax. Also an engineer visit was organised resulting in the bad external wiring being replaced removing two instances of corroded crimped connections in the process.
So thank you to all that helped.
There still seem to be problems with the line (dropped PPPoA sessions) which I will start a new thread for.
Message 20 of 20
So part the way there
