apr
Message 1 of 5
poor broadband Upload speed
BT have just upgraded my home hub 2 to a home hub 3 to address poor download speed.  There has been a significant improvement for download speed.  great.  However, my Vodafone Suresignal now only works intermittently with my caller only hearing garbled speech, though I hear my caller fine
Looking at the various threads this seems to be because of poor upload speed.  Testing via the BT speed test, or speettest.net, my upload speed seems to vary from 100K to 320K with a typical speed of 200K.  The spec for suresignal says it requires 350K, so this seems to be the issue
I spoke to BT who say that 200K speed is acceptable and they do not guarantee any speed though the marketing says up to 1M.  they said they would "refresh" the line.  however this has made no difference
reading the various threads I can see that my exchange has been updated to 21CN and my line is an ADSL2+ (router says it is modulation G.992.5 Annex A).  I am about 1km from the exchange and the attenuation figures quoted from my hub are 20.4 dB / 10.4 dB.  So in theory I think I should be getting far higher upload speeds (up to 1.4M)
Checking the BT speed test it appears that line is capped at 448K, as diagnostics say Upstream Rate IP profile on your line is - 0.45 Mbps
Is there a way to improve upload speed without having to buy "infinity"
4 REPLIES 4
Message 2 of 5
Re: poor broadband Upload speed
Can you post up the connection stats from your home hub please?
Can you also post up a screenshot of the results for your number from http://www.dslchecker.bt.com please.
apr
Message 3 of 5
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
Featured Products
WBC FTTP Availability Date
Left in Jumper
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)54.34010.27--Available----
VDSL Range B (Impacted)41.322.48.54.6--Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 12--6.5 to 17Available----
WBC ADSL 2+ Annex MUp to 12Up to 16.5 to 17Available----
ADSL MaxUp to 3--2.5 to 6Available----
WBC Fixed Rate2----Available----
VDSL Multicast------Available----
ADSL Multicast------Available--
Message 4 of 5
And the hub connection stats?
Are you aware that BT Infinity is available to you? Infinity 1 would give you speeds of around 50meg download and 7-9meg upload.
apr
Message 5 of 5
yes I am aware of infinity but apart from upload speed, I don't need the extra capacity at present so why pay the extra.  Here are line stats
ADSL Line Status
Connection Information
Line state:Connected
Connection time:3 days, 00:53:51
Downstream:18.33 Mbps
Upstream:443.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):2.3 dB / 27.7 dB
Line attenuation (Down/Up):20.4 dB / 10.4 dB
Output power (Down/Up):20.3 dBm / 11.9 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):149702 / 32
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):4869600 / 7
Error Seconds (Local/Remote):6160 / 0
