Message 1 of 38
random pole
hello am trying to sort out fibre for my area in central newquay cornwall and have noticed a random polee whic75264851_10218299619654375_6079784244828176384_n.jpgh is connected to another pole outside my estate but neither are connected to anything any engineer can tell me what this polke is for for it was put in this year
37 REPLIES 37
Expert
Message 2 of 38
Re: random pole
Hi @woolfman ,
Openreach doesn't reply here, so you won't hear from an engineer the purpose of this pole.
It is likely to be a telephone pole, and the cable may come from underground; which is why it is not connected to anything.
You can check what broadband is available to you from BT here: https://www.dslchecker.bt.com/
Post results but remove the Cabinet and phone number.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 3 of 38
Re: random pole
there are no cables running to it and there is another pole about 12 feet away which provides our awful broadband  phone lines which sometimes struggles to play netflix and yet on the area checker on open reach it says the area has been done its doing my head in and tried your checker and yes only thins available is hardly 8mb 😞
Message 4 of 38
Re: random pole
if you are a bt broadband customer then post dslchecker results from phone number
Expert
Message 5 of 38
Re: random pole
They may be underground.
While close to 8mbps is not fast, it is enough to play standard definition and high definition (if no one else is online). Have you got a strong wifi signal?
Please post the results from the website mentioned (https://www.dslchecker.bt.com/) and run a speedtest here: http://speedtest.btwholesale.com/
Message 6 of 38
Re: random pole
i have strong wifi signal and noone else lives with me cant seem to work out how to copy that page edit it and post it
Message 7 of 38
Re: random pole
e Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsADSLOther Offerings
Availability Date
Premise environmentStatus
WBC ADSL 2+Up to 16--14.5 to 18Available----
WBC ADSL 2+ Annex MUp to 16Up to 1.514.5 to 18Available----
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate2----Available----
Max Observed Downstream Speed (Mbps)9.41
Max Upstream Observed Speed (Mbps)1.23
Observed Date2019-09-29
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date15-10-20
Expert
Message 8 of 38
Re: random pole
Thank you for posting
Message 9 of 38
Re: random pole
also im a gamer and have to download huge files sometimes i lived in the country side and had 38mb fibre now i moved into center of one of largest towns in cornwall cannot get fibre its silly tbh
Message 10 of 38
Re: random pole
connection speed seems low compared to expected range   can you post stats from your hub  which hub version do you have?
