Message 11 of 38
Re: random pole
2a00:23c5:f424:b701:3224:78ff:fec5:ba01
 Global unicast prefix/length:
2a00:23c5:f424:b701::/64
 Link local address:
fe80::3224:78ff:fec5:ba01
 Remote link local address:
fe80::a67b:2cff:fe4e:a1f
 DNS:
Not available
IPv6 LAN details
 Global unicast address:
2a00:23c5:f424:b700:3224:78ff:fec5:ba03
 Link local address:
fe80::3224:78ff:fec5:ba03
Message 12 of 38
Re: random pole
bt smart hub type a
Message 13 of 38
Re: random pole
BT Hub 6A
Serial number:
+084318+NQ84875011
Firmware version:
SG4B1000E01E
Firmware updated:
26-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
3 Days, 10 Hours 19 Minutes 29 Seconds
Data rate:
1.22 Mbps / 9.63 Mbps
Maximum data rate:
1212 / 9956
Noise margin:
5.3 dB / 4.9 dB
Line attenuation:
36.5 dB
Signal attenuation:
15.9 dB / 36.5 dB
VPI / VCI:
0/38
Modulation:
G_992_5_ANNEX_A
Latency type:
Fast Path
Data sent / received:
1715 MB Uploaded / 44780 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-HW9N
2.4 GHz wireless channel:
Channel 11
5 GHz wireless network name:
BTHub6-HW9N-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
30:24:78:C5:BA:03
Software variant:
Boot loader:
9.2.0
Message 14 of 38
Re: random pole
your speed is about attainable but I would have thought would be higher with your attenuation
was that a manual reset 3 days ago?
have you tried using the test socket with a filter to see if that helps improve your connection speed
any line noise  dial 17070 option 2  should be silent and best with corded phone
as no fibre available got to see if you can squeeze anymore speed
Message 15 of 38
Re: random pole
its on a filter all the time on main socket and was a manual reset as couldn't even surf the net
Message 16 of 38
Re: random pole
ok but have you tried using the test socket which is behind front plate with a filter to eliminate your internal wiring and faceplate from causing any problems  when in test socket check that there is no dial tone at any extension socket whether in use or not
Expert
Message 17 of 38
Re: random pole
The two boxes on top look like Connectorised Block Terminals for FTTP.
Although I’m not familiar with the box halfway up the pole, usually the Splitter and Intermediate Nodes Openreach use are an oval shape but then it’s not uncommon for different types of technology to be used on the Access Network in different parts of the U.K.
Then again it might belong to a different Network Provider, there should be a 3m mark on the Pole (letters and numbers etched into the pole) and it should have the initials of the owner there. If it says ‘BT’ at the top of the birthmark then it’ll be BT’s/Openreach’s.
Message 18 of 38
Re: random pole
Hey yup its bt as has it etched in the side brings a glimmer of hope they gonna get fibre to here thnx
Expert
Message 19 of 38
Re: random pole
You can check if there are plans here: https://www.openreach.com/
Even if it says not, don’t give up hope. This site is known for not being very reliable!
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Distinguished Guru
Message 20 of 38
Re: random pole
I can confirm it's an openreach fttp connectorised distribution point. The fibre feed is the single cable fed from an adjacent pole.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
