Message 11 of 15
Re: slow broadband
can you post hub stats please
you can see if you upgraded to fibre you could get connection speed in range 80/74mb
Message 12 of 15
Re: slow broadband
2.4 GHz Wireless Configuration
Wireless SSID:BTHub4-8JNG
Wireless interface type:802.11 b/g/n (up to 144 Mb/s)
Security:WPA & WPA2 (Recommended)
Channel selection:Automatic (Smart Wireless)
5 GHz Wireless Configuration
Wireless interface type:802.11 a/n (up to 300 Mb/s)
Security:WPA2 Only (Recommended)
Message 13 of 15
Re: slow broadband
That is just wireless information
can you
hub.
From the top Menu > Troubleshooting
> Helpdesk
> Bandwidth
You may be able to gain a little more information from the event log, such as the SNR Margin, shortly after a resync.
Troubleshooting >
Event Log >
Category 'WAN'
Message 14 of 15
Re: slow broadband
I managed to get hold of the BT complaints service. My speed is now back to 4mbps. Thanks for your help.
Message 15 of 15
Re: slow broadband
Hi @gin2ger
Thanks for posting back to let us know your speed is back up to where it should be.  I'm really pleased to see that 😁
Cheers,
Robbie
