Message 41 of 51
Re: unreliable broadband - please help
still a couple of days to go - have you been able to stay connected 24/7 with no disconnections?
Rob_Hale
Message 42 of 51
ye 24/7 so far
Rob_Hale
Message 43 of 51
hi again
Download speedachieved during the test was - 108 Kbps
 For your connection, the acceptable range of speeds is 50-250 Kbps.
 Additional Information:
 Your DSL Connection Rate :6688 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 135 Kbps
still no change dsl still stable :(, can't it just update already lol
Message 44 of 51
if there is no change by tomorrow then I would contact the mods for assistance as it looks like your profile is stuck at 135  http://bt.custhelp.com/app/contact_email/c/4951
Rob_Hale
Message 45 of 51
another phone call this morning, apparently it'll take 10 - 14 days to get maximum connections, i was wondering does this mean that it'll still be very slow sometimes, or should it be awesome compared to now (just wondering cause if i can get 1000kbps or so then i can still use the internet and download items till it stabilises at a better connection rate)
Message 46 of 51
with your curent speed you should get a profile of 5500 as shown here http://www.kitz.co.uk/adsl/IPprofile.htm
If you still have a stable connection showing 3+ days then contact the mods as I suggested miss out India
Rob_Hale
Message 47 of 51
the eagle has landed
 Download speedachieved during the test was - 4996 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 5500 Kbps
 hopefully it'll stay good now =D
Message 48 of 51
it's more than landed - your down speed has increased to 8128 and if you can maintain that for 3/5 days again you could see your profile go to 7000/7150:smileywink:
Rob_Hale
Message 49 of 51
Download speedachieved during the test was - 6502 Kbps
 IP Profile for your line is - 7150 Kbps
=D
Message 50 of 51
wow
success:smileywink:
