Message 1 of 26
zero upload speed so cant work from home. HELP!
Live in a village.
BB has always been poor, but recently I have ZERO upload speed.
So Zoom meetings are impossible.
25 REPLIES 25
Message 2 of 26
Re: zero upload speed so cant work from home. HELP!
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
 please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 26
My Home Hub
My Services
Internet:
Connected
Disconnect
Broadband username:bthomehub@btbroadband.com
BT Wi-fi Status:Active
BT Access Control:Disabled
Configure
My Home Network
Network Device MAC Address IP Address
Devices currently connected to your BT Home Hub:
2.4 GHz Wireless:Unknown-22-23-f6-...22:23:f6:a6:61:12192.168.1.68
5 GHz Wireless:HPD99953.home40:b0:34:d9:99:53192.168.1.65
Ethernet:DESKTOP-HVLLTFS04:0e:3c:34:66:2d192.168.1.78
USB:No devices detected
The BT Broadband service comes with a selection of supporting software applications and supplementary services.
These include BT Wi-fi to allow you to go online anywhere, security software to provide online protection and tools to diagnose and fix connection problems
Find out more and complete a Smart Setup installation for your current device.
Find out more about BT Wi-fi.
Message 4 of 26
Have run quiet test, which is fine.
Reported situation to BT who say they have repaired a fault.
file:///C:/Users/steph/Downloads/PerformanceTestReport%20(3).pdf
Message 5 of 26
If a fault has just been repaired, then try a single disconnect of the broadband input for about 20 seconds, that normally sorts the problem out.
Message 6 of 26
Done, no change
Message 7 of 26
@mrunhappy1 wrote:
Done, no change
What speed are you supposed to get, what does this page show against your phone number?
Please remove phone number before posting full  results.
Which BT Home Hub are you using?
Message 8 of 26
Did you try as requested from @imjolly ?
If so, kindly provide a screen shot of the result.
Message 9 of 26
Message 10 of 26
Pls advise how to get screen shot
Using windows 10
