Message 1 of 2
Best Mesh WiFi System in 2026 | Expert Guide
I researched  the best mesh WiFi system over the last few days because I need stronger and more reliable internet coverage throughout my entire home. I checked reviews from The New York Times (Wirecutter), Consumer Reports, and Popular Mechanics, and these two models are rated as the top choices:
NETGEAR Orbi 370 Series Dual-Band WiFi
TP-Link Deco BE63 Tri-Band WiFi
But I am still unsure which one would be the right fit for my setup and would appreciate your expert opinion. My home has multiple smart devices, several 4K TVs, security cameras, laptops, gaming systems, and I also need strong signal in the basement and backyard. At the moment, I am dealing with weak spots and inconsistent WiFi in different rooms.Which one should I go for any suggestions would mean a lot. thanks in advance
[Mod Edit - Third party links removed]
1 REPLY 1
Message 2 of 2
Re: Best Mesh WiFi System in 2026 | Expert Guide
I am intrigued why you've looked at reports from The New York Times (Wirecutter), Consumer Reports, and Popular Mechanics.
These are all USA publications and their reviews may well be principally applicable to US broadband installations.
Are there no UK based reviews that you can consult?
