Message 1 of 5
Change username if possible
Hey everyone! Is there to change my USERNAME?
Message 2 of 5
Re: Change username if possible
You cannot change your username. Mods may be able to help and they will post here
Moderator
Moderator
Message 3 of 5
Hi @TopflightApps As you have just created your forum profile please can you confirm that is your forum username you are looking to change or is it another username?
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
kipper99
Message 4 of 5
I’d like to change my username @JohnC2 how do I go about that?
Moderator
Moderator
Message 5 of 5
Hi @kipper99,
I'll be able to help you change your Forum username. I've sent you a PM, please drop me a reply and I'll get that done for you.
PaddyB
Community ModeratorPaddyB
Kudos”
